Old 01-04-15, 05:55 PM   #11
JonSV
Default Re: Pirelli SC's and tyre warmers
Interesting topic this. I dropped my pressures a few psi for my last trackday to 30 front and 32 rear when cold and both tyres ended looking like this. Not too bad I guess, but I maybe need to drop pressure a little further? They were much worse on the previous trackday despite riding slower.
I think tyres warmers should be banned from trackdays unless there are power sockets available - the continuous generater noise drives me mad. The riders with slicks and warmers and in the novice group make me laugh though!
Old 02-04-15, 07:24 AM   #12
speedyandypandy
Yes, your hot pressures for the front should be around what you just wrote, but always check with the spec sheet, but an educated guess would be around 30-31 front and 29-30 rear, always lower rear pressure.
Some rear tyres (D212) has a 'hard' rubber carcass, and should be around 20psi hot, so checking your spec sheet is important.
Tyre warmers for novices are "head voodoo" helps confidence, but more than likely hot tyre temp is lower after a outing than going out.
For info, I dabble in race weekends and trackdays, I change my tyres myself, and balance them myself. And bring along laminated spec sheets for all my different tyres.
Old 02-04-15, 02:20 PM   #13
petro53
So I'm a bit confused. It looks like the SP is the road version and SC are track. The reason I believe this is that the SC tyres are only sold by track vendors in the US. It also looks like the SC's are harder to get compared to the SP's here in the UK. Are the SP's more forgiving? Meaning that I should get the same steering and roll feel? In other words since I am a novice and don't want to tear up tyres from the lack of knowledge about them, would it be moire cost effective to run the SP's for a while till I get faster. Or am I just over thinking this.
Old 02-04-15, 04:15 PM   #14
speedyandypandy
No you're on the ball, keep going...
I'm out-of-date on the Pirellis(3 last seasons on Dunlop/Michelin beacuse of price), but I'm sure if you're not knee scraping and sideways out of corners the DIABLO ROSSO CORSA will be enough to take you up to most advanced/fast groups.
Old 02-04-15, 04:34 PM   #15
Stu
Trinity
Stu's Avatar
Yes you're right, SP are for road. (The poster above that stated R1's & 1298's sic came on SC was confused.)
If you're not in the fast group I would consider selling the SC's & buying something more suitable, like any sports road tyre. (M7RR, Sportssmart, Rosso Corsa, S20 etc.)
Old 02-04-15, 05:34 PM   #16
Red Herring
Red Herring's Avatar
I think that would rather depend on the state of the SC's. If they came with the bike are they scrubs (already been used)? If so you won't get enough for them to cover buying alternative new rubber so just ride on them and worry about what to buy when you have to, given by then you will have a whole lot more experience upon which to base your decision.
Old 03-04-15, 12:36 PM   #17
wideguy
If you aren't using them hard enough, race compound tires won't heat up enough to grip well, so it's possible for a novice track rider to have less available grip from race tires than from street sport tires. Modern street sport tires, especially dual or triple compounds, will allow you to drag your pegs on the track in pretty fast turns. If you aren't doing that, you don't need race compound tires.
You can lower the tire pressures on your race tires to make them heat up at a slower pace, but they might start to feel squirmy under braking and acceleration at the low pressures. If you do run them, watch for signs of cold shearing or overheating, try to be smooth on the throttle and smooth on turn ins and transitions and don't just snatch the brakes full on. That's good advice anyway.
Old 03-04-15, 01:47 PM   #18
petro53
You just hit the crux of it for me. I'm sure at my current pace the tyres would actually cool, off the warmers. So again the SP's seem more appropriate for now. So I have one pair of Scrubs (not mounted) and a new pair that is currently on the bike. I think I should sell/trade the new pair for a set of SP's. Then I'll keep the scrubs for when I get faster. Again, Thanks for the imput.
Old 03-04-15, 03:45 PM   #19
nutzboutbikes
+1
The Rosso Corsa's are a great tyre, I use them on trackdays in the intermediate group.
Which tyre warmers? Minty101 Mini-Twins 13 26-11-13 07:49 PM
Set off tyre warmers will take upto a 190 rear tyre £80 sv650k4 For Sale - Other Bikes and General biking items 8 01-10-13 11:07 AM
3 sets tyre warmers and 1 pirelli front slick chunkytfg For Sale - Other Bikes and General biking items 0 09-08-09 06:58 PM
Tyre Warmers Olly For Sale - SV's and SV related items 0 06-10-08 01:59 PM
Tyre Warmers- again sorry tomjones2 Bikes - Talk & Issues 8 10-01-08 11:39 AM
