Old 18-07-15, 09:41 PM   #11
NTECUK
NTECUK's Avatar
Default Re: Need help with my track bike
If it turns when not engaged with engine it not pulling much current.
So any resistance in the circuit has less of an effect.
That's were the meter good. It shows you were the volts drop.
So if needs to be checked in the engine.
The biggest volt drop is across the starter (11 Volts probly as your loose some across the solenoid and all the connections ).
So check out the volts drop. Volts on your meter. Probly range will be 20volts. Put the -ve or common on the meter probe on the -ve battery terminal.Then the pos probe to the frame. Then keep the -ve battery terminal connected. Them +ve probe to the engine.
Any more than 0.65 volts is bad.
If that's OK with the meter -ve still on the -ve on battery -ve terminal and the positive probe on the input of the starter. The meter reading should be 10 volts min when you crank it.
Old 19-07-15, 06:13 AM   #12
Degener8
Degener8's Avatar
No problem il do.that as soon as im home, what would be the solution if its reading more than 0.65?
" By the Power of Grayskull... "
Degener8 is offline   Reply With Quote
Old 19-07-15, 07:16 AM   #13
NTECUK
NTECUK's Avatar
Clean up the contacts or if it's a broken wire replace it unless you can get a replacement terminal.
If it a drop across the starter relay /solenoid, it's a new one.
I guess you have put the bike in gear and it will turn over.
Old 19-07-15, 09:50 AM   #14
Degener8
Degener8's Avatar
Okay, with the alternator cover off and the gear spur removed between the starter motor and the one way clutch cog, the starter motor spins, with the multimeter on the connection it reads 11v.. When the spur is connected the 3 move about 1 - mill then stop, when I release the button it moves backwards the same? I really really really appreciate you being so patient with me im trying to get this sorted between 12 hour weekend shifts at work lol.
Old 19-07-15, 08:01 PM   #15
Degener8
Degener8's Avatar
Thanks to everyone that helped, but the engine is siezed good and proper so it's up to the mechanic now.
Cheers for your help with everything!
John
Old 21-07-15, 02:57 PM   #16
jambo
jambo's Avatar
Yes the missing question here was does it turn by hand.
Before all hope is lost, have you removed the plugs and tried turning it over? You occasionally find a leaky carb has flooded a cylinder and hydraulic locked the engine (petrol does not compress). I've had this happen in the past, it's annoying but worth checking before you condemn the motor. Don't have your head anywhere near the spark plug hole when you turn the motor over after removing the plugs by the way, it may come out quite fast...
If this is the case, drop the oil out as it may have been contaminated with fuel, and also check the carb floats & needles, as well as any fuel taps.
Fingers crossed
Jambo
Old 21-07-15, 04:20 PM   #17
NTECUK
NTECUK's Avatar
Post two Mr Spiers first past the post on that one....
What I missed was the bit about it didn't turn.
Ops
Old 21-07-15, 07:32 PM   #18
Degener8
Degener8's Avatar
Fingers crossed
Jambo
Ops
Yeah i got my buddy round to help me, it's stuck for sure . Ive since learned it's spent a year standing under a car port. Its booked in to my.mechanic now on Monday it's well past my abilities. Originally it was deemed a starter motor issue and it's just escalated lol. As soon as I know what the diagnosis is il update doesn't matter how broken it is though il still mend it lol
Old 10-08-15, 10:48 AM   #19
Degener8
Degener8's Avatar
The engine is genuinely siezed.
It's dropped 2 exhaust valves on cylinder 4
But there is all bits in engine so is going to want a full strip.
The bikes coming back so I can drop the engine out myself and get it ready and keep Cost low but a second hand engine is £350 but is more hassle to collect and prep etc plus we know this engine more than sone random second hand job which could die in a week.. So
Old 11-08-15, 01:47 PM   #20
Degener8
Degener8's Avatar
Here's the culprits
SV as track day bike? stranger12 SV Talk, Tuning & Tweaking 13 08-12-14 04:22 PM
2004 / 04 Suzuki SV 650 Championship Winning Minitwin Race Bike / Track Bike V5 . Supertwin ? stevetwedd For Sale - SV's and SV related items 0 02-11-12 06:10 PM
Track bike swifter Racing and Paddock Chat 12 18-06-11 10:09 PM
FS: Yamaha FZ600 Track bike. Bargain first track bike! NC24 For Sale - Other Bikes and General biking items 1 29-10-10 02:59 PM
