Old 28-10-15, 11:50 AM   #11
Biker Biggles
Biker Biggles's Avatar
Default Re: Sv650s Curvy Running Issue
Madly fluctuating voltage could cause electrical oddness. Take it you have checked voltages with multimeter?
Try fully charge the battery and disconnect the 3phase charging wires to the reg-rec... see if this runs normally. Obviously it won't for long as there will be no charge.
Rather than checking the sidestand switch etc.... actually bypass them at the fusebox including bypassing the cutout relay. Just 2 wires to join.
Won't be anything to do with the clutch switch as that only prevents starting.
"Take it you have checked voltages with a multimeter"
Do this before you spend any more money replacing expensive bits.
Old 28-10-15, 12:15 PM   #12
https://www.youtube.com/watch?v=0n6oNFfcCOA
http://www.electrosport.com/media/pd...ng-diagram.pdf
Follow Geo's links
Old 28-10-15, 02:25 PM   #13
doghammer
I had an issue with similar symptoms.
Turned out to be small hole in the rad, that was chucking coolant into the front plug (which was brand new). Had to replace plug and give the cavity a good clean out.
Curvy running issue. dirtydog SV Talk, Tuning & Tweaking 145 24-07-13 04:13 PM
SV650s running on 1 cylinder Roberrrrt SV Talk, Tuning & Tweaking 26 15-02-11 11:38 AM
I think my sv650s k5 is running rich? kev_sv650s SV Talk, Tuning & Tweaking 5 24-11-10 09:53 AM
SV650S Running hot calypso67 SV Talk, Tuning & Tweaking 7 23-05-10 07:33 PM
Help with minor running issue and noise Jay1 SV Talk, Tuning & Tweaking 6 13-02-08 03:48 PM
