Old 23-02-16, 08:43 PM   #11
seanmhc
Default Re: Front suspension assembly slightly corroded
I'm located in West Yorkshire, about 20 mins out of Leeds if you're on a bike.
Should be getting the bike on Thursday provided everything goes smoothly so I'll be able to see what's next from there.
Would any recommend/advise against buying a pair of 2nd hand ones from eBay, providing worst case scenario?
I'm really not sure about the idea of nail varnish or superglue on anything that isn't cosmetic, haha.
Old 23-02-16, 09:12 PM   #12
Nail varnish, super glue or araldite are all short term bodges.
If the rust spots don't extend to where the seal passes over, then you should be fine.
2nd hand ones are fine, so long as they are straight and not damaged or rusty.
You can also get pattern ones for £112
http://www.brooksuspension.co.uk/suz...kcqBoCxVfw_wcB
Wemoto do them also.
Don't fork out for them unless absolutely necessary
One Front Indicator assembly breakz187 Stuff Wanted 2 10-06-10 04:12 PM
Advice / options slightly bent front wheel (curvy) Interceptor SV Talk, Tuning & Tweaking 31 07-04-09 01:30 PM
Front forks are corroded. Elio SV Talk, Tuning & Tweaking 7 27-02-09 01:03 AM
Front Master Cylinder Assembly drag Stuff Wanted 2 06-08-08 09:50 AM
Front brake handlebar assembly Colby SV Talk, Tuning & Tweaking 3 13-03-07 03:48 PM
