Old 05-03-16, 06:57 PM   #11
Swin
Swin's Avatar
Default Re: Shoulder checks and SV650s position
I would recommend getting some mirror risers, they only stick the mirrors out by an extra inch or so, but the amount of extra rear vision is incredible
Riding a V-strom, well it has an Sv engine, don't it
Swin is offline   Reply With Quote
Old 05-03-16, 08:42 PM   #12
This, improves rear view greatly
Old 05-03-16, 09:41 PM   #13
Adam Ef
Adam Ef's Avatar
Cheers.
Looks promising.. any idea where to get them? All links seem to be to USA eBay.
Old 05-03-16, 09:46 PM   #14
Curvy - http://www.ebay.co.uk/itm/Mirror-Ext...jXgsH38gl-woMw
Pointy - http://www.ebay.co.uk/itm/1-Mirrors-...YAAOSwjVVVsOAr
Old 05-03-16, 09:54 PM   #15
Adam Ef
Adam Ef's Avatar
Brilliant. Cheers. These are definitely on the list of bits needed.
Old 06-03-16, 02:03 PM   #16
PyroUK
PyroUK's Avatar
100% recommend the risers for the mirrors, you should hopefully find that the extra visibility afforded by these will ease the nerves as your situational awareness will be greater.
I had them on the SV and now the Daytona, as a slightly larger lad all I could see in my mirrors previously were my own shoulders!
This does not make for a relaxing ride, put the extenders on and it was like an epiphany.
Riding should never feel like a chore
2011 Triumph Daytona 675, Arrow exhaust and QS!
PyroUK is offline   Reply With Quote
Old 06-03-16, 06:23 PM   #17
Trev B
Trev B's Avatar
I got those extenders after I fitted the bars on mine and the bars give much more movement with the head,looking left and right vision was vastly improved,BUT to improve the mirrors even more I bought a pack of 4 of those round rubber door stops from the pound shop and 4 x75mm Allen studs and added these between the extenders and the mirrors,Total cost £2.90p.No more elbows and forearm !!!
Somewhere up north,Never regret something that once made you smile!!!
Trev B is offline   Reply With Quote
Old 06-03-16, 07:09 PM   #18
tom_e
I've already got a set of extenders on mine, might pick up another set and some longer bolts and stack them as I still suffer from a decent view of my elbows/shoulders.
Old 07-03-16, 08:49 AM   #19
Corny Gizmo
The real problem was that the HGV was parked up on double yellows just round a blind corner on a fairly fast road, but wrong or right these situations will occur, so I want to be as best prepared and equiped as possible to deal with them.
Like the others have said, building a mental image is everything. In this situation with a mental image of traffic around you, you could be 80%-90% sure of what was in the right lane, use a quick glance to double check and move over. Without a built up mental image of the traffic around you, you have to do a full check and lifesaver etc before moving over.
Its a constantly evolving mental map and if done correctly... if you absolutley had to, you could change lanes without checking your blindspot, because you know what is there. (I would never do this purposefully but if someone stops suddenly etc you may have to.)
I guess what im trying to say is always have an escape plan.
Old 07-03-16, 08:49 AM   #20
Corny Gizmo
Crash.NET - Shoulder checks for Iannone after testing fall NewsBot News 0 12-05-15 03:00 PM
HPI Checks - £6 each instigator For Sale - Other Bikes and General biking items 3 29-05-12 11:24 AM
HPI checks for £6 Stu For Sale - Other Bikes and General biking items 14 19-02-10 08:08 PM
Busted shoulder Milky Bar Kid Idle Banter 33 08-08-09 07:37 PM
CRB Checks Dappa D Idle Banter 30 10-03-09 09:35 PM
