Old 12-02-17, 10:52 PM   #11
R1ffR4ff
R1ffR4ff's Avatar
Default Re: Cheap"Cyclone" Alarm fitting/Review
Just to add an update.It took than less than 30 mins for the,"05" Gel sealed battery on my SV to charge on a trickle/tender charger.This tells me,by experience and my electrical/electronic knowledge,the battery is still in good nick.
So as of 4pm 12/02/17 ish today I enabled the Alarm and see what happens over the week
Old 13-02-17, 04:30 PM   #12
Blapper
Blapper's Avatar
If the battery is a bit sulfated, it will indicate it is charged but will not be. Anywaysup, let's see what your charge is like after a few days. Report the voltage here.
Old 15-02-17, 12:41 PM   #13
R1ffR4ff
R1ffR4ff's Avatar
Originally Posted by Blapper View Post
If the battery is a bit sulfated, it will indicate it i charged but will not be. Anywaysup, let's see what your charge is like after a few days. Report the voltage here.
I'm waiting until Saturday to check the voltage or some time soon but it was @ 12.8v when the alarm was initiated.I will try starting the bike on Saturday so it will have a full week.
Old 17-02-17, 07:19 PM   #14
R1ffR4ff
R1ffR4ff's Avatar
Update:
I was going to wait but decided to check the battery today.It was at 12.8v when fully charged and today,after 6 full days with the alarm on over 95% of the time and even when not armed still connected and read as 12.1v.
Bike started first time on the button.
Some of the lost current will also be due to me checking some Stop/Tail light stuff with the side lights on now and then as well.
If the bike were in daily or regular use I cannot see a problem with the Alarm being on.As I'm not putting the bike on the road until Early march and the alarm will still being used I'll not charge the battery and see how it goes.
Also at the standard factory sensitivity setting yesterday I slammed my Garage door(Corrugated metal garage) and the alarm went off!
This sensitivity can be changed from the key-fobs but for me this is a plus as I was going to alarm my Garage as well.
Old 18-02-17, 01:24 AM   #15
Northern Biker
Good review, thanks.
What does the siren/chirp sound like?
Shrill screaming cat?!
Old 18-02-17, 08:36 AM   #16
Blapper
Blapper's Avatar
R1ffR4ff: Those voltages are too low so either your multimeter's calibration is out or you are not reading direct from the battery terminals.
If the battery is fully charged, after resting to settle the voltage, the voltage is 12.5 = 85% charged, 12.4 =65% charged, 12.3 =50% charged 12.2 =35% charged, 12.1 = drained. If those figures of yours are right, your battery is too low to store without charging. If you store it below 85% the rate of sulfation increases massively and your prize is a knackered battery in the spring.
Old 18-02-17, 09:55 AM   #17
SV650rules
http://www.mmbalmainauto.com.au/PDF/..._batteries.pdf
here is useful chart showing battery terminal voltage and state of charge
Before taking a voltage reading always let battery sit for at least half an hour (preferably an hour) after taking charger off for the voltage to settle down.
2016 SV650 AL7
Old 18-02-17, 10:12 AM   #18
R1ffR4ff
R1ffR4ff's Avatar
Yes it's a really loud shrill beep.My kitchen is about say 20/25/ foot from the Garage and bike and I can still activate/deactivate from there
Old 18-02-17, 10:12 AM   #19
R1ffR4ff
R1ffR4ff's Avatar
I'll keep an eye on it and will put my trickle charger/battery tender back on it.It's a sealed battery so don't know if that makes a difference.
I've just tested my house mains AC voltage with the meter and it reads 237v which is around what I would expect.
Old 18-02-17, 10:52 AM   #20
R1ffR4ff
R1ffR4ff's Avatar
Update.
I decided I wanted to know the brand of the battery so have just had it out.It's a Dynavolt Sealed and was fitted 28/05/15 and not year 05 as I first thought I saw.Put battery back in and read 11.9v.Bike started on-the-button with a bit of choke.I've left the bike running for a while as I don't how often the engine has been used since the bike went up for sale.
Have put the battery back on my "Oxford Optimizer"
Bibios "Gizmo" mini review & Novice install. rictus01 SV Talk, Tuning & Tweaking 4 11-08-14 08:20 PM
Single Seat Cowl """damaged""" lechatenetpat For Sale - SV's and SV related items 8 05-12-12 03:03 PM
another "widepants car review" thread Wideboy Idle Banter 41 19-10-09 10:29 AM
Epic Review of the "Barmouth or Bust" Ride out xXBADGERXx Idle Banter 3 05-04-09 08:44 PM
