Old 24-02-17, 03:37 PM   #11
aesmith
Default Re: EBC vs DP brake pads for modulation?
Originally Posted by daktulos View Post
This may seem like an odd question, but when do you use the rear brake enough to wear it down?
If aimed at me there are two reasons (1) riding all year round I'm often on slippery surfaces when I'll tend to use the back a lot more than the front. (2) I've had an ongoing problem that the back only wears one pad, meaning that one pad does all the work and therefore wears out. Fingers crossed that particular problem gets resolved by the last of many overalls. However even if the pads then lasted twice as long, they'd still wear out quicker than the front.
Old 24-02-17, 04:00 PM   #12
NTECUK
NTECUK's Avatar
After you had a Knee Op and don't feel your dragging the break FFS
Old 24-02-17, 04:14 PM   #13
daktulos
daktulos's Avatar
Just a general question really - as I mostly stick clear of it apart from at lights, I can't imagine it ever actually wearing down. I guess I don't ride in slippery conditions if I can avoid it, though.
daktulos is offline   Reply With Quote
Old 24-02-17, 04:22 PM   #14
ophic
ophic's Avatar
I use mine for exercising my foot. It does naff all else
Silver SV650SK3, Fuel exhaust
Old 24-02-17, 04:37 PM   #15
NTECUK
NTECUK's Avatar
Um if you do a bit of fun.
Not that I'm encouraging it like
How do you control a wheelie???
Old 24-02-17, 05:44 PM   #16
aesmith
The guy I bought the bike from was amazed I even used the back brake at all. Mind you he rides almost exclusively on the track so his rear wheel probably isn't even on the ground when he's braking.
Old 24-02-17, 09:17 PM   #17
Adam Ef
Adam Ef's Avatar
For very slow riding in traffic. To scrub off a bit of speed if i'm slightly fast into a corner (as opposed to using front). Probably not enough to wear pads very fast. Most of the wear on mine was there from the previous owner. I use mostly thinking ahead and engine braking to slow me and a bit of front brakes and fraction of rear at the last minute to come to a stop.
Old 25-02-17, 07:53 AM   #18
Blapper
Blapper's Avatar
Yes. What Adam said. Using the front brake in a corner (especially on an SV with standard forks) changes the steering geometry too much whereas dragging the rear is just enough.
Old 25-02-17, 10:14 AM   #19
NTECUK
NTECUK's Avatar
I have found that using the back helps keep the bike more stable.
Even in practicing emergency stops.
Filtering I use the back as it's good to balance the bike
Hardly use the front below 10 mph.
Old 25-02-17, 11:48 AM   #20
Blapper
Blapper's Avatar
I think it would be interesting to see someone do low speed manoeuvring without using the rear brake?
brake pads Richie Bikes - Talk & Issues 7 19-08-14 04:27 PM
SV Racing Parts, GSXR Brake Caliper Adapter Brackets, & Galfer SS Brake Lines & Pads sv-racing-parts SV Talk, Tuning & Tweaking 42 15-09-11 10:27 PM
Which brake pads? loonytoon SV Talk, Tuning & Tweaking 30 15-02-11 09:21 PM
Which brake pads Lucas SV Talk, Tuning & Tweaking 10 04-11-09 05:50 PM
EBC Pro-Lite brake discs and Goodridge GH brake pads r4ce_e3nd For Sale - SV's and SV related items 7 14-04-07 07:37 PM
