Old 04-04-17, 07:20 PM   #11
Lumpy
Angry Re: Bent and ground rear foot level - MOT fail?
I bought the one from m&p . What you see is what you get . No little screw on bracket for the return and brake light switch . Just had to spend another £25 for a genuine 2nd hand . That's £50 NOW .
Old 04-04-17, 08:14 PM   #12
yokohama
Default Re: Bent and ground rear foot level - MOT fail?
I snapped mine, bought this one to replace it but it's the standard pedal.
Fitted and working no problem.
http://www.ebay.co.uk/itm/New-Suzuki...-/232125825504
Old 04-04-17, 08:20 PM   #13
aesmith
I think I can borrow a lever, so with the MOT wheels, my spare forks and borrowed brake pedal I should be good for a pass. Everything can be swapped back after the test.
Old 04-04-17, 08:47 PM   #14
tom_e
As long as you can still operate the brake it'll be an advisory.
Old 16-04-17, 06:48 PM   #15
Qkley
Thanks for all the suggestions. The MOT has been passed. The lever has not been mentioned once. Happy days!
July Photo Comp - Ground Level View - VOTE OFF SuzukiNess Photos 75 06-08-12 06:04 PM
Need a bent ally rear subframe leebex Stuff Wanted 3 25-11-11 07:33 PM
Damaged, bent rear subframe for pointy weecorey Stuff Wanted 2 22-05-10 11:04 PM
Slightly bent rear rim? nobby SV Talk, Tuning & Tweaking 9 06-04-09 08:08 PM
Curvy rear subframe ... bent, f'd ... whatever yorkie_chris Stuff Wanted 4 30-09-08 05:48 PM
