#11 |
Out of interest to build up a picture of R/R failures how olds the bike and how many miles? And was the bike started with a flat battery before this problem happened ie bumped, jumped etc
Thanks |
#12 |
It's a year 2000 and I've done around 40K in mileage. There was no charge in the battery, out of the blue. I put enough charge in the battery to start it and go for a test ride but as no charge was going in (unbeknown to me at the time!) it quickly ran out and I had to push it home. The last couple of short local rides had obviously been draining the battery with nothing topping it up as I hadn't had it plugged into the optimate. Once plugged into the optimate, it charged up fully again and has had no problems holding its charge while I've been starting it up to do checks. The battery's checked out good and not weak.
#13 |
If you haven't already,buy a Workshop manual.People often overlook just how useful the,"Troubleshooting" sections are in these.For example,
![]() You can get them from Halfords or Amazon etc. I sometimes just pick up mine and read it as a book just so I can get to know the machine ![]()
#14 | |
#15 |
Well, I've replaced the rectifier & still only getting 1.2 V out of the top of it to charge the battery with. All checks up to that point with a multimeter are fine, I've even replaced some wires between the alternator & rectifier. I can't find anywhere what the output of the alternator should be, is 147 V at 5000 revs from all 3 phases too high? The Haynes manual says max output of 300W which doesn't help me!
#16 |
For my 1999 Curvy,
#17 |
Thanks, my manual is giving the same figures. Guess I need to work out the volts into watts!
#18 | |
http://www.ohmslawcalculator.com/ohms-law-calculator but 147v is way too high to me.Something amiss with the Stator methinks. All the 3-Phase Stator failures I've had have been shorted coils(no output) or coils to ground(no output).Never seen one go,"High" but I suppose it's possible.Just a guess but maybe some coils have shorted and putting out more than they should and screwing up the A/C :/ I've already done a bit of research in case I ever need a new Stator and found this http://www.bbbikeshop.co.uk/acatalog...ternators.html http://www.bbbikeshop.co.uk/acatalog/Regrectsuzu.htm But with those you have to re-use your old connectors.There's some on eBay with all the connectors on ready to fit. I think my,1999 "Curvy" is a G5 type?
"Stultus est sicut stultus facit" Last edited by R1ffR4ff; 15-06-17 at 11:39 AM. |
#19 |
Just to be clear, you are talking 1.2V DC aren't you? You're not forgetting to change from AC to DC after checking the stator outputs? If you are saying the output is 147V AC when measured between all three phases, that is very high, but the output of 1.2V DC from the reg/rect is waaay too low. Something is amiss somewhere.
Where you from mate? |
#20 | |
SV650S K9 Battery Charging Issues. | morgoth | SV Talk, Tuning & Tweaking | 3 | 22-03-16 03:25 PM |
Charging Issues | Nick8529 | SV Talk, Tuning & Tweaking | 60 | 02-07-15 07:27 AM |
Charging issues. | farquare | SV Talk, Tuning & Tweaking | 6 | 30-04-12 08:46 PM |
Car - battery/charging issues - any ideas? | SV650S_DUB | Idle Banter | 3 | 27-01-10 10:07 AM |
The sources of my woes (charging issues and more!) | thedonal | SV Talk, Tuning & Tweaking | 22 | 25-09-08 08:18 PM |
