09-08-17, 04:43 PM | #11 |
Re: What is this and how do I make one...
maybe you should save your money and learn how to bump start a bike instead. if your battery has gone flat then you have either left your side lights on or your battery/charging system is fubar. if the battery has gone flat due to leaving your lights on then a bump start should get it going again, if its the battery/charging system then jump starting it from a capacitor or even a battery is not going to get it going.
09-08-17, 05:27 PM | #12 |
That capacitor would never start a bike but may have been used a a smoother on vehicle electricity circuit to take any ripples out. A bank of them may start a bike but it would need a few that size connected in parallel - that blue fuse looks like a 60 amp 'maxi-fuse (blue).
If a bike has a duff battery it may run if you put a capacitor in to replace battery and bump start it. see last post on this forum http://www.caferacer.net/forum/techn...otorcycle.html As apprentices we used to charge up higher voltage capacitors with a 'megger' insulation tester and chuck them to someone.
2016 SV650 AL7 Courage is resistance to fear, mastery of fear, not absence of fear - Mark Twain Last edited by SV650rules; 09-08-17 at 05:33 PM. |
09-08-17, 08:27 PM | #13 | |
I keep meaning to find a big hill and keep practicing until I get it, just have not got round to doing that yet and was intrigued as to what the device was. I have a couple of times turned the ignition off one click too far and put the parking lights on, come back and there is just not quite enough juice to start it. I have seen those commercial battery pack that can jump start a car/bike but this home made one looked like a bit of fun to make!
New Girl Sets Up YouTube Channel on SV650- see my channel; Tamsen Cooper Like, Comment, subscribe |
09-08-17, 08:42 PM | #14 |
Some people can run alongside the bike then jump on sidesaddle and bump start it, but being an uncoordinated tool I'm pretty sure it'd be all bump and no start if I tried it. I had an old piece of junk at uni, bumped it God knows how many times, mainly by being pushed and using 3rd gear.
12-08-17, 05:51 PM | #15 |
You are treating a symptom and not a cause.
If you are using up batteries there's something wrong with the charging system.The workshop manual has checks for the Stator and the Regulator/Rectifier. In a previous post I pointed to these Power Boost Jump Starters, https://www.amazon.co.uk/DBPOWER-800...r+jump+starter I have a pal who has one and they work.
12-08-17, 07:09 PM | #16 |
The curvy SV reg/rec is known to be rubbish. It is old tech and gets no cooling, a recipe for disaster.
I replaced mine with a MOSFET unit, far better without doubt. The SV is a very hard bike to bump start, only attempt with someone else pushing, even then you will struggle. |
12-08-17, 11:14 PM | #17 |
I doubt you could bump start if the battery is completely flat. It happened to me and there wasn't enough juice to get the fuel pump to prime. No fuel, no start.
Some say the cup is half empty, while others say it is half full. However, both are wrong; the real problem is the cup is too big. Honda 125 CG blown engine Gone to the great mechanic in the sky Naked SV650 K3 in Silver |
13-08-17, 08:39 AM | #18 |
Curvy doesn't have a pump?
Was: K2 naked in rapid yellow - gone to a better? place Now: Street Triple R |
13-08-17, 08:47 AM | #19 |
13-08-17, 08:48 AM | #20 | |
What will it make? | andrewsmith | Idle Banter | 30 | 16-11-13 08:44 PM |
Whats needed to make a carby 650 make 72bhp? | Sy-superfly | SV Talk, Tuning & Tweaking | 8 | 12-09-11 11:08 AM |
Tetley make tea bags make... | Bear | Soho Massive | 7 | 14-03-11 08:48 PM |
Does Anyone Make These? | I'm_a_Newbie | Bikes - Talk & Issues | 10 | 27-10-10 05:30 PM |
Make up artist of make up artists... | noisie | SV Talk, Tuning & Tweaking | 0 | 03-10-07 05:22 PM |
