Idle Banter For non SV and non bike related chat (and the odd bit of humour - but if any post isn't suitable it'll get deleted real quick). There's also a "U" rating so please respect this. Newbies can also say "hello" here too. |
07-03-18, 09:16 PM | #11 |
Re: Shed Build
Good info in here, my wife and I are at the house hunting stage but nothing has popped up yet and if we can't get one with a garage then it will be a decent shed.
Sent from my Xperia using Tapatalk
07-03-18, 09:21 PM | #12 | |
Re: Shed Build
Good point Lance, if I orientate it correctly and have the slope going towards the boundary then I should be ok. I have created a plan for the roof joists and placed the 18mm ply floor on top of 45 x 95 joists at 400 centres.
Previous: Suzuki SV650S K9 - Sold Suzuki GSXR1000 K8 - Wrote Aff Honda Fireblade RR-9 - Sold Yamaha MT 10 - Sold Current Bike: Aprilia Tuono V4 Factory |
07-03-18, 10:25 PM | #13 |
Re: Shed Build
dont go too mad with the timber your not putting a car in there. 600 spacing is fine with dwangs. using 400 without dwangs can result in things moving, better with dwangs.
use treated rough sawn. use dpm on bottom of walls where it connects to the floor. |
08-03-18, 10:34 AM | #14 |
Re: Shed Build
Cheers Lance
Floor redrawn with 600 CL timbers and dwangs. Got the studwork up too. Just need to work out door and window size and locations. Gable wall with structural opening for the door. I will add some dwangs in to support the worktop etc. Roof rafters will have gussets and strengthening diagonals.
Previous: Suzuki SV650S K9 - Sold Suzuki GSXR1000 K8 - Wrote Aff Honda Fireblade RR-9 - Sold Yamaha MT 10 - Sold Current Bike: Aprilia Tuono V4 Factory Last edited by TheRamJam; 08-03-18 at 01:33 PM. |
08-03-18, 01:47 PM | #15 |
Re: Shed Build
if you lay the flooring along the 2.4 you can use 2 dwangs. the dwangs need to be staggered or you wont be able to nail the ends or use lap joints and nail from above.
which ever way you lay the flooring you need to make sure that all ends sit on a joist. if your going to line the inside with PB or chip then you need to remember to have stud to fix to in the corners so go one size up for that purpose. lets say you use 50x75 for the main frame, you would either need to nail 2 bits together in the corners along the side frames or use 100x75 in the corners (ends of frame). or put the '75' face on, on all stud work. again use dwangs if you can. building a shed is the exact same as building internal stud walls in a house. Last edited by Bibio; 08-03-18 at 01:51 PM. |
08-03-18, 04:34 PM | #16 |
Re: Shed Build
Wtf is a dwang? Do you mean noggings?
Talk English man. |
08-03-18, 06:46 PM | #17 |
Re: Shed Build
north of the border here... lol
08-03-18, 09:00 PM | #18 |
Re: Shed Build
If you are thinking of storing your motorbike in the shed be careful, as already discussed on this forum your insurance will insist on a brick or concrete structure.
http://forums.sv650.org/showthread.php?t=229280
2016 SV650 AL7 Courage is resistance to fear, mastery of fear, not absence of fear - Mark Twain Last edited by SV650rules; 09-03-18 at 12:44 PM. |
21-03-18, 08:22 PM | #19 |
Re: Shed Build
I have decided to opt for a lean to shed build. Construction costs will be roughly 12% cheaper and probably easier for my basic DIY skill level. This is what I have drawn, it's 1800 wide instead of 2500 wide and 3600 long.
The plan shows a L shape worktop for the moment but this could change as this effectively limits the space to single sided working on the bike at any one time. However the outline shape of the bike is exaggerated because its calculated at its widest part being the tips of the wing mirrors. I wish to put a few sockets into the shed and a light switch. Any ideas as how i could connect this up to run off power from the house?
How to build a shed | Stenno | Idle Banter | 12 | 07-04-13 02:43 PM |
Where is my new shed?! | Fallout | Idle Banter | 33 | 12-09-12 03:28 PM |
Shed for Sale !!! | Ch00 | Idle Banter | 10 | 25-08-07 10:31 AM |
Shed! | phil24_7 | Idle Banter | 1 | 02-07-07 09:21 PM |
Would someone shed some light... | JakeRS | Idle Banter | 28 | 03-03-06 09:38 PM |
