18-03-19, 08:21 AM | #11 |
Re: Piston slap or valves?
You can even do it without draining the coolant, just unhook the radiator and let it dangle on the hoses (supporting it on a box or similar).
18-03-19, 10:24 PM | #12 | |
I think you are right - as long as one is careful (maybe wrap the radiator in some bubblewrap to protect it) then I think there might be just enough room to do the checking bit. If the shims need changing it might be a bit cramped, but one could decide whether to remove the radiator for that bit. Sent from my iPad using Tapatalk |
20-03-19, 07:41 AM | #13 |
Based on the vid clip (and I know microphones can distort the sound so just guessing) I would be thinking cam chain rattle especially as it quietens off briefly when you increase the revs.
20-03-19, 09:47 AM | #14 | |
A lot of SVorgers in USA post that cam to valve clearance actually gets slightly larger as engine warms up, so that should get noisier as well.
2016 SV650 AL7 Courage is resistance to fear, mastery of fear, not absence of fear - Mark Twain Last edited by SV650rules; 20-03-19 at 09:49 AM. |
20-03-19, 11:50 AM | #15 |
It will be interesting to know what the problem is. It just sounds like a worn cam chain to me. I am probably wrong. I often am
20-03-19, 05:19 PM | #16 | |
Have you managed to eliminate the clutch/transmission from the list of suspects yet (or not perhaps)? Have you had any success searching for the noise with a stethoscope? I'm intrigued - what is causing the noise? Alan |
20-03-19, 06:02 PM | #17 | |
Here's how my SV sounds with the Slip-on exhaust in a Metal garage recorded on a Smart phone, https://app.box.com/file/218563217522 My 10 penn'th.
"Stultus est sicut stultus facit" Last edited by R1ffR4ff; 20-03-19 at 06:05 PM. |
20-03-19, 07:52 PM | #18 |
I think I'd want to be looking at the cam chain, the tensioner, and the tensioner blade.
20-03-19, 10:05 PM | #19 | |
I've not gotten round to checking clutch yet but I will get to it this week! Along with a stethoscope! As far as cracking the cover off for checking clearances, do I need a replacement gasket or is it a re-useable rubber gasket? Also I should be able to depress the cam chain and check whether it's loose while the cover is off right? Cheers. |
21-03-19, 07:11 AM | #20 | |
https://www.fowlersparts.co.uk/parts...1173-19F01-000 You may download a good service manual and the parts list (free) from here (see pp 3-109 I think): https://www.carlsalter.com/suzuki-service-manuals.asp Last edited by Othen; 21-03-19 at 02:53 PM. |
Slap my Ham... | gruntygiggles | Idle Banter | 37 | 15-11-10 10:23 PM |
Chain slap? | swinging_simian | SV Talk, Tuning & Tweaking | 9 | 31-08-09 09:43 AM |
Piston Slap at 2000 miles? | royboy4652 | SV Talk, Tuning & Tweaking | 8 | 16-07-08 07:55 AM |
Slap a co-worker day | Stu | Idle Banter | 2 | 05-10-07 11:11 AM |
Well slap my tank! | DanAbnormal | Idle Banter | 2 | 14-04-07 08:39 PM |
