#11 |
My bike has done over 21100 miles and the sprocket and chain have been jumping, so last week I bit the bullet and got the garage to source and fit a new sprocket and chain set. Parts £102 plus 2 hours labour
plus VAT of course. The labour included working on a jammed gearbox and binding front brake.
Some say the cup is half empty, while others say it is half full. However, both are wrong; the real problem is the cup is too big. Honda 125 CG blown engine Gone to the great mechanic in the sky Naked SV650 K3 in Silver |
#12 |
wow you got bigger ones than me! Id be poopin if I had a chain jumping plus it doesnt do the rest of the drive train much good as it increases wear on the cush drive and gearbox bearings. To keep costs down I spent a little on a chain breaker/rivetter and change my own chains very easily....
#13 |
#14 | |
#15 |
I had a side plate break on my Z400. Luckily in town and at low speed so all that happened was lots of clanking and a very jerky feel. Looking at the broken side plate it seems like a crack had been developing for a while before letting go, then when it broke the other side bent leaving the two pins splayed out. Lucky I only had to go a couple of miles to a friendly dealer who fitted a spring link for me as a temporary measure.
#16 |
Probably the shock of the loose chain on the sprockets finished it off when its skipped.
Chain info and When to change chain? | doofus4000 | SV Talk, Tuning & Tweaking | 8 | 22-04-13 03:54 PM |
Naked curvy chain guard and chain | Squatepantz | Stuff Wanted | 0 | 10-05-11 07:41 PM |
Which chain adjustment marker (new chain) | rockster | SV Talk, Tuning & Tweaking | 14 | 22-11-09 02:12 PM |
Morax Gold Chain Wax / Wurth Chain Wax | glade | Ancillaries | 3 | 14-02-08 06:41 PM |
Will stiff chain link cause chain noise | dclifford | SV Talk, Tuning & Tweaking | 8 | 16-08-05 11:56 AM |
