Old 18-07-19, 06:41 PM   #11
Lordspectre
Default Re: Right indicator now working
Appreciate that now I know what to be looking out for t
Lordspectre is offline   Reply With Quote
Old 18-07-19, 07:48 PM   #12
Othen
Default Right indicator now working
Originally Posted by Lordspectre View Post
Many thanks, will pick up a voltage tester in the morning
You could probably get a multimeter from Maplin for a tenner, get the cheapest one, it will be fine and last a while, you will use it lots of times.
You could always use a 12v bulb and a couple of bits of wire if you don’t have a meter, you just need to see whether there is a signal or not. Another way would be to find the first connector block after the switch and use a little bit of wire to connect the black wire to the green one, if the problem swaps sides then the switch is at fault.
Sent from my iPad using Tapatalk
Old 19-07-19, 04:35 PM   #13
Toooldtodie
Toooldtodie's Avatar
I had my right indicator go and the wires had rubbed on the fairing and failed over the years.. took the little black cover off from rhs of the binnacle and the problem was clear.
My two penneth.
Thought I was in a bad mood, but it's been 30 years now, so I suppose it's just who I am.
05 SV650s now with proper suspension, hurrah!
Toooldtodie is offline   Reply With Quote
Old 19-07-19, 06:04 PM   #14
Othen
My two penneth.
... but in this case the hazard lights still work both sides, so the wiring must be okay to the luminaire, don’t you think?
Old 20-07-19, 08:20 AM   #15
Lordspectre
Well lad. I honestly don't understand the terminolgy of binnacle. I know rhs is right hand side that's it
Old 21-07-19, 07:19 AM   #16
Biker Biggles
Biker Biggles's Avatar
"Binnacle"---The bodywork that surrounds the instrument cluster. Its a nautical term for the housing around a ships compass.
Old 21-07-19, 08:31 AM   #17
Lordspectre
Thank you
Old 23-07-19, 08:08 PM   #18
Lordspectre
Did a it of a sand with a fine sanding lad fix it up for you? I got as far as opening up he control unit and checking he switch and it looks fine and slides quite smoothly . I'll have out had part tomorrow evening and see if corroded. Cheers
Front right indicator not working Bobbydazzer31 Bikes - Talk & Issues 3 05-08-14 09:49 PM
Indicator not working (Right indicator) Randomdude SV Talk, Tuning & Tweaking 7 19-02-14 01:35 PM
RHS rear indicator not working Nobbylad SV Talk, Tuning & Tweaking 13 14-08-13 01:04 PM
Front Indicator not working, rear flashing fast along with dash RavenWire Bikes - Talk & Issues 7 17-05-10 11:14 AM
SV650s K2 Indicator Warning Light not working kd80 Bikes - Talk & Issues 0 05-04-10 08:51 PM
