#11 | |
My best guess at the moment is that there's a high resistance link between the reg/rec and the battery. The larger the load, the larger the voltage drop across it, and so the lower the maximum voltage the battery would be charged to. Thanks. |
#12 | ||
If there is a high resistance link it would most likely be at a connector. On a Street Triple it's usually the connector between the stator and the reg/rec and it can get hot enough to melt the plastic cover on the connector.
2016 SV650AL7 2023 GSX-8S |
#13 |
#14 | |
![]() I've used it a couple of times to help neighbours out ![]()
#15 | |
"Stultus est sicut stultus facit" Last edited by R1ffR4ff; 01-11-19 at 10:35 AM. |
#16 |
Well, that's interesting. I know more, but still don't have an answer.
Firstly, at the battery - after yesterday's ride which finished with the bike staring pretty normally. Off - 12.67V - so something like 85% charged. Idling(ish) - 13.5V Idling(ish) + lights - 13.2V Idling(ish) + lights + grips - 13.1V 5000rpm - 13.4V 5000rpm + lights - 12.5V 5000rpm + lights + grips - 12.3V So, if this is right, the battery would likely discharge on the motorway to around 70%. Even without the grips, it's not great. I ran through the full ElectroSport diagnostic flowchart, and there were no problems anywhere. Voltage at the R/R (don't compare with above as this was later and I had the choke out above): Idling - 14.1V 5000rpm - 13.5V So, it looks like there are two separate factors: 1. The voltage drops with an additional load. Not unexpected, but it should be able to cope with just the headlight. 2. The voltage drops when the engine RPM increases from 1400 to 5000. This is unexpected. Other than static tests, which are all fine, I can't test any of it in isolation. The only test I can think of (and this is my current plan) is to buy some spade connectors to measure the current being drawn from the reg/rec. My gut feeling is that the R/R is unhappy, but can't explain it. Any ideas? |
#17 | |
Ignoring the voltage drop with increasing revs for the moment which is not that unusual if you google it, your voltages are on the low side but not by a huge amount. You could check the stator a/c output voltage but they usually fail catastrophically. With it disconnected from r/r you'd normally be getting >70v a/c at 5k I'd charge the battery, trace the wires (usually yellow) from the stator to make sure they're intact and clean any connectors along the way to the reg/rec. I'd disconnect the +12V plug from the r/r (red and black wires) and clean its connections. I'd clean up the battery connections not forgetting to check the negative connection to the frame. One fairly common mod on Triumphs (and other bikes) is to rewire the dc side of the r/r using thicker cables (4mm squared) direct to the battery (with 30A fuse on the pos lead). If none of that helps, then I agree, change the r/r. Incidentally, Decosse on Triumphrat has written an excellent guide that will tell you how to diagnose charging issues, what type of r/r are available, which connectors are being used (to connect r/r) and where to buy them (last part not so good since he's in US): https://tinyurl.com/y5oldlfz
#18 | |||||
#19 |
Do a Diode test on the R/R.The procedure is in the manual and pull apart and clean the in-line block connectors.My Curvy had two but I've now removed them as per,
https://cx500.000webhostapp.com/Mosf...sfetUniRR.html
#20 | |
If you feel so inclined you can use a MOSFET type, which are generally more reliable and stable, the semi-conductors have a lower volts drop across them so less heat is produced internally. I've fitted various ones from different bikes in the past, my SV has one from a Honda ATV, the Deauville has a ZX10 item. Plenty to choose from on fleabay if you are capable of doing the appropriate rewire. You can get the correct connectors, but I used simple 1/4" spade terminals with plastic covers, the alternator wires are all the same so no issues, you just need to get the pos/neg output wires correct. Online search will identify which is which in the output socket. The MOSFET R/Rs usually carry an "FH" ident, so FH012, FH014, FH020 etc are all potentially suitable. Shindengen is the usual name, and Eastern Beaver do various fitting kits if interested.
Curvy down on power. | baldricc | SV Talk, Tuning & Tweaking | 9 | 18-03-14 10:38 AM |
Loss of power - Curvy. | juliensc | SV Talk, Tuning & Tweaking | 5 | 05-10-13 12:12 PM |
Slight power delivery type problems. | Dave20046 | SV Talk, Tuning & Tweaking | 11 | 19-06-09 10:46 AM |
pointy power and vibration problems | pookie | SV Talk, Tuning & Tweaking | 4 | 17-10-08 07:26 AM |
curvy 650 power problem | adam_castell | SV Talk, Tuning & Tweaking | 4 | 27-08-08 08:30 AM |
