Old 22-02-21, 05:25 PM   #11
SV650rules
Default Re: K4 SV650 Reg/Rec
Seems not to be your RR then, but just a note about Electrex RR851 - it is a 'series' regulator, which means that instead of fully loading the stator coils all the time like a 'shunt' ( parallel) RR and dumping excess current not used by load as heat the 851 'series' one actually has a regulator in 'series' with load - this means it only draws enough current from stator to satisfy the load, I fitted one last year to my AL7 and did some test of heatsink temperature - the original Shindengan heatsink ran at over 70degC and the Electrex one ran 30degC cooller ( on same day at same ambient temperature ). I am not able to get a temperature for the stator coils, but being a lot more lightly loaded they have to be running considerably cooler. At the same time I fitted a digital voltmeter to handlebars, I found that when I ran feed to digital voltmeter from sidelight bulb ( on all the time ignition is on ) I was getting a reading 0.4 volts lower than when I ran feed straight from battery terminals ( voltage drop in the connector plugs and wiring ) - now it is 14.4v to 14.5v all through rev range.
https://www.electrexworld.co.uk/acat...Rectifier.html
2016 SV650 AL7
Old 27-02-21, 02:32 PM   #12
check the connector on the RR as i had same problems but turned out to be a furred up terminal. those connectors are waterproof but in the same breath they also collect moisture inside.
sv650 to sv650 to sv1000 to sv650 to MT-03 Anybody owned one? ian505050 Bikes - Talk & Issues 9 11-09-11 10:50 PM
2000 sv650 stanchion on a 2004 sv650? kaimera SV Talk, Tuning & Tweaking 6 09-06-11 10:06 PM
Red SV650 Seat, Oxford Indicators & SV650 bits. MattSV650 For Sale - SV's and SV related items 2 09-04-11 09:43 AM
G-PACK for SV650 SV650S SV 650 SV650 S - EFI MODELS - Timing Retard Eliminator ThEGr33k SV Talk, Tuning & Tweaking 0 25-11-07 12:22 AM
will a 2002 sv650 s cylinder head fit my 99 sv650? bugsy46 Bikes - Talk & Issues 2 07-04-07 04:26 PM
