Old 24-03-24, 08:42 AM   #11
SV650rules
Default Re: Brake fluid musings
Sometimes the rubber diaphragm stays inside the cap when you remove it, on other reservoirs it stays in the neck of the reservoir and you have to pull it out to add fluid, there will often be a plastic filter in the bottom of the reservoir to stop any bits that may be in brake fluid ( who re-uses brake fluid ? ) or maybe a bit of rubber breaks off the cap or diaphragm and filter will catch it. John T is correct that fluid does darken in the system, this may not be from water, just aging / contamination of the fluid... You can clearly tell old fluid by it being darker, and sometimes by the smell.
2016 SV650 AL7
Old 24-03-24, 10:21 AM   #12
glang
You are indeed correct Sir! Ive just checked my Sandero and as you say theres a rubber diaphragm up inside the cap - does make sense...
DOT 5 Brake Fluid DJ123 SV Talk, Tuning & Tweaking 4 04-08-11 09:14 AM
Is this brake fluid okay for the SV? Scythe92 SV Talk, Tuning & Tweaking 8 29-03-11 11:13 AM
Brake Bleed nipple/Mityvac/Brake Fluid query Ceri JC SV Talk, Tuning & Tweaking 15 20-01-09 02:04 PM
Brake Fluid & Oil krhall Bikes - Talk & Issues 6 20-12-06 12:58 AM
Brake fluid Trix SV Talk, Tuning & Tweaking 14 20-01-05 11:13 AM
