Old 18-05-24, 10:40 PM   #11
stevieo
Junior Member
Default Re: Cam chain tensioner - no slot??
Well I wasn't worried about this, now I am ! -
Im thinking as long as I re-check the clearances after its all back together, put the cams back on in the right position and dont refit the tensioners extended then all should be good. Can you point me to any other problems that may arise?
Thanks Steve
stevieo is offline   Reply With Quote
Old 19-05-24, 06:26 AM   #12
glang
Have a good read of the manual beforehand and you'll be fine. Its just a case of marking and recording everything as it comes apart, not letting the chain go loose back down in the barrels, not dropping anything in the engine, not mixing bits up on reassembly and not overtightening bolts into soft alloy...
Old 19-05-24, 07:00 AM   #13
glang
oh and if your lucky and very careful (go round them with a feeler gauge or something before lifting off) you might be able to reuse the cam cover rubber gaskets which I think are quite expensive to replace...
Old 19-05-24, 01:48 PM   #14
admin
John T
admin's Avatar
I'm paranoid so I'd turn the engine over by hand when you're finished just to ensure there's no valve piston interference. In case of a cam timing error.
Old 19-05-24, 03:10 PM   #15
glang
Yes good point and it reminded me of a Suzuki vee twin I did recently (not SV) where I got in a right pickle. I think youre supposed to do one cylinder at a time and I would recommend this as I tried to dismantle both at the same time to give more choice for swopping shims around.
However doing this means you have to rotate the crank with one cam set removed plus then to get back to the correct position for the first you have to rotate a long way and its easy to get confused whether youre on the firing or exhaust stroke. The crank mark lines up the same for both and I hadnt marked the chain so with no cams its very difficult to know when the electronics will produce the spark!
More by luck I got it right and all was well but I lost some sleep as it wasnt my bike....
Old 12-06-24, 04:33 PM   #16
stevieo
Junior Member
Thanks for all the advice, finally got round to it and all good, all clearances are pretty much in the center of spec now. Cranked by hand first, then a short burst with no plugs in, then started first time and runs fine.
I ended up taking all 4 cams out and doing the timing from scratch using the manual, so cams in correct position on front on F mark, then rotate 360 and do the rear also on F mark. Next check is at 95K!
Old 12-06-24, 04:40 PM   #17
admin
John T
admin's Avatar
Well done. Not a job for the faint hearted.
Old 12-06-24, 05:40 PM   #18
glang
If you took all 4 cams out at the same time how did you know the crank was in the right position when putting them back in? As I say the crank mark comes round twice for every revolution of the cam but only one of those crank positions is the correct one for the cam F mark....
Old 19-06-24, 07:32 AM   #19
glang
Well if anyone else is doing this job and wants to take out all 4 cams at the same time (best to enable mixing and matching of shims) I strongly recommend marking the chains at the right positions. Then from what I can see as long as the chains arent moved on their crank sprockets its the only way to be sure of correct reassembly....
The manual doesnt mention this because it talks only of doing one cylinder at a time.
Anyone got a K3 cam chain tensioner? Taipan Stuff Wanted 7 24-02-12 04:17 PM
Cam Chain Tensioner - Which one? ShadFX SV Talk, Tuning & Tweaking 2 10-06-10 11:50 AM
Cam Chain Tensioner hardhat_harry SV Talk, Tuning & Tweaking 5 22-03-10 12:00 AM
cam chain tensioner jimmy SV Talk, Tuning & Tweaking 2 21-06-09 02:27 PM
Cam Chain Tensioner Jamie_SV SV Talk, Tuning & Tweaking 3 01-09-08 12:55 PM
