Old 17-01-05, 04:32 PM   #11
lairylarry
- Is the spacer sticking in the fork leg? Any notches on the outside stopping it from sliding all the way into the leg? If so, get some medium / fine wet and dry and rub it for 5-10 mins. Should make it slide a bit more freely (it will stick in place when you do the clamp bolts up!)
- Is the speedo drive definitely located correctly?
- Try putting the spindle in loosely, leaving the clamp bolts undone, put the calipers on and squeeze the brakes on while the bike's still on the stand. Sometimes sorts out the alignment.
- Got anything softer than a screwdriver? Try tapping the spacer a bit harder with a brass drift, or maybe a piece of wood. (With the front wheel off the floor)
Old 19-01-05, 05:01 AM   #12
bigE
Thanks for the tips but i gave up and took it to the shop yesterday . I will post what happened to it. Thanks again
Wanted: Curvey 99-02 Front Wheel Rim & Axel in Silver slloyd Stuff Wanted 2 04-05-09 11:17 AM
POINTY front wheel spindle/axel in V.G.C sv650k4 For Sale - SV's and SV related items 9 03-09-08 08:25 PM
So how are you supposed to put the lid on the front brake reservoir? 2mths SV Talk, Tuning & Tweaking 31 04-06-07 06:12 PM
Flush front indicators jon SV Talk, Tuning & Tweaking 18 30-07-05 10:06 PM
front flush mount turn signals- 03 SV650/S SRT2KEN Bodywork 18 02-07-04 01:38 AM
