#11 |
A quick phone call to a Suzuki dealer in my town, kind of confirmed all you guys said.
His response was along the lines of ".....it`s only a four grand bike, what did you expect? ......good luck!" Not the response I was hoping for. However the dealer I bought the bike from is 20 miles away and I went there in the first place because they are better at dealing with people. I hope I have more luck. |
#12 |
yes but emphasise 4 grand is four grand and at the end of the day if a 2 yr old car rusted that quick that woudl be unaceptable, but the fact our bikes rot is acceptable!!
keep trying mate Alex |
#13 |
I have an 03 SVS which I have ridden through everything and the cases started corroding. I went into the dealer, they took pics and emailed them to Suzuki, Suzuki said ok & they replaced the parts under warranty. I am about to get the same done for my forks causes the paint is coming off the bottom of the fork leg.
My dealer said I have a two year warranty, regardless of mileage and if Suzuki think I have a claim they will replace them. So if you see fit to make a claim, your dealer is just a go between and I would kick up a fuss if they do anything other than be helpful. |
#14 |
Suzuki will look at it no doubt, generally finish is not covered in all aspects but they have done quite a few in the past..if your bike is less than 2 years old then give it a go. But believe me being polite about it helps you as i can understand why some dealers are unhelpful when customers walk in demanding and F*ing and blinding...and believe me it does happen more than you think...we are only human so obviously get upset!.
Take some photos too yourself if you have the means, that way the less the dealer has to do, makes it easier for you to get a quick answer. anyway, the not fit for purpose in this case..how would that work?. Would some rust make the bike unfit for use?. If so then i am giving my SV650 back as its not quick enough ![]() |
#15 |
My '02 has no real corrosion problems and it is documented that the mark 1 bikes are slightly better finished than the later bikes.
Suzuki have heavily discounted the later bikes compared to the original prices and i cant help wondering whether as a result of this, they have compromised the quality of the manufacturing process. Just a thought. ![]() |
#16 |
My SV650Sk3's 18 months old, covered 9000 miles and lives outside all the time, my local dealer recently replaced the headstock and one of the peg hangers due to corrosion which must have been a fair amount of labour and they were fine with it, no hassle, took it in, they had a look, took a picture, ordered the parts, sorted it pretty quick and even lent me a bike when it was in. For the record the dealer was All Bikes in Rochdale who I've always had good service from and they remember me whenever I go back in too which is always neat!
![]() The little guard on the oil cooler's just started to go on mine too, but to be honest for the aggro I really can't be ar*ed to do anything with that unless something else decides to go. If you get nowhere with a dealer, just try another one as it's a Suzuki warranty, not just something that's to be done by the place you bought it from. |
#17 | |
The bike I have now is a K3, again I had it from new and it has been treated exactly the same and the corrosion problem is not even on the same scale as the 2000 bike. I recently had the left engine cover replaced as the paint was starting to bubble and I have replaced the furry bolts with stainless. The K3 looks far better after two years than my 2000 model did after one. The problem with warranty claims always seems to be with the dealer. I have had to claim against the warranty four times on the two bikes and have only ever had problems getting the dealer to put the claim in, once this is done the work gets done in double quick time. On my first bike the small tube in the top of the petrol tank became detached from the tank (the weld had broken) causing petrol to leak from the filler cap when the bike was leaned over to the left. This occurred about three months after the warranty had expired and Suzuki agreed to replace it without a problem the only fight was getting the dealer to put the claim in. As was said before try going direct to Suzuki if you can't get any joy from a dealer. |
#18 |
binky 61,
How can you tell with a rust coloured bike? ![]() |
#19 | |
![]() ![]() ![]() ![]() Quote:
Corrosion on K7. | daveb | SV Talk, Tuning & Tweaking | 2 | 06-03-09 04:19 PM |
Warped front discs - warranty claim? | RingDing | SV Talk, Tuning & Tweaking | 3 | 05-02-07 08:41 PM |
Result-Warranty claim ok'd by Suzuki | diamond | Bikes - Talk & Issues | 7 | 27-12-06 09:43 AM |
Corrosion | Dave C | SV Talk, Tuning & Tweaking | 6 | 01-08-05 03:54 PM |
corrosion | big twin grin | SV Talk, Tuning & Tweaking | 0 | 29-01-05 08:53 AM |
