Old 01-04-08, 02:34 PM   #11
ljharmitt
Default Re: Speedo Bulb
anyone got a link to where i could get some? Or some blue ones ?
Old 01-04-08, 02:43 PM   #12
Viney
Blue ones dont work. The colour dulls them down too much. I have blue bulbs that i got off ebay. I have tred LEDs and all manner of stuff, and in all honesty, clear white or amber only.
As for getting them, Ebay, local car shop. You just need 1.2w festoon bulbs or Dash bulbs as most epople call them.
Hope this helps
Edit - https://www.autobulbsdirect.co.uk/pr...cat=588&page=2
Old 01-04-08, 05:27 PM   #13
Halfords sells them too
Old 02-04-08, 12:40 AM   #14
ljharmitt
Thanks
Old 02-04-08, 09:49 AM   #15
gavinsky23
Anyone know thw part number for the Halfords ones, so as I can get them before I take the fairing etc off?
Old 05-10-12, 09:11 PM   #16
Skopak
Wink Re: Speedo Bulb
Originally Posted by Viney View Post
A list(in order of removal)
Mirror pods
1 cross head screw
2 6mm Hex bolts
2 rubber threaded grommets
Each side pannel consists of
3 medium head 4mm hex bolts
1 large head 4mm hex bolt
1 push pin (Underneath front)
1 cross head screw (Front air duct)
Front center section
4 4mm medium head bolts (2 become visible after you remove side pannels, 2 are underneath)
(Leave the 2 3mm small head ones at the bottom of the screen and remove center section and screen combined)
Clock shroud
1 4mm Medium head Bolt (In front of head stock)
2 Cross head screws
Clocks to remove
4 7mm(i think) nuts with washers
1 Multi pin plug
Clocks to dismantle
6 cross ehad screws
As i said, replace all 3 bulbs with 1.2w versions form Halfords, all with the carriers attached. I have tried LED's but thier light angle doesnt light the entire clocks. So stick with the bulbs for now.
HTH
And thats from Memory...does that make me sad???
I've just had a bulb blow on the speedo on my curvy. I can see what speed I'm doing over 50mph, but no idea what speed I'm doing below that at night. So pleased I found this thread - &, what a great run-down of strip & assembley for such a major upheaval just to change a bulb. Like others have said, I'm going to change all bulbs while my curvy's in bits. Thanks Vinny.
Just keeping the thread alive for any one else with the same problem.
Old 09-10-12, 06:24 PM   #17
Skopak
Talking Re: Changing speedo bulbs on Curvy?
Job Done. About 1.5 hours from start to finish (including 15 minutes trying to get an LED out of the clocks because it fell out of the holder).
I'm not sure what the clocks are like on a Pointy, but on a Curvy, there's rubber grommets on the back to remove the bulbs, so there's no need to take the clock housing apart.
Apart from the messing around with the fairing, the job is quite simple, even for a noob like me .
Old 27-09-16, 07:59 PM   #18
EdMayle
Default Re: Changing speedo bulbs on Curvy?
Hiya, Just had my first ride in the dark in ages and aspotted mine have all gone. One had gone before but i could still see up to 70 and as carelesschucca said, anything over that and I'm in trouble anyway.
I've just ordered these, have i got the right thing?
http://www.autobulbsdirect.co.uk/R50....2W-Black.html
Old 28-09-16, 06:48 AM   #19
Blapper
Blapper's Avatar
I haven't had to do this myself, but Viney's post says these:
http://www.autobulbsdirect.co.uk/R50...ck.html?page=2
Old 03-10-16, 10:55 PM   #20
EdMayle
Thanks mate. I read his post and followed the link but those are discontinued so I went for the product the website recommendedicated as a replacement. Just hoping someone who had done it might be able to have a look at the image and let me know if they looked right.
Changing dash bulbs? dazzaboy Bikes - Talk & Issues 17 05-10-12 09:29 PM
Changing Speedo Bulbs? dazzaboy SV Talk, Tuning & Tweaking 4 10-03-11 08:06 AM
Curvy R&G tail tidy with Mini-Indy's - Changing Indicator Bulbs, how? krhall SV Talk, Tuning & Tweaking 2 08-03-09 06:55 PM
Changing Light Bulbs... Drew Bikes - Talk & Issues 8 25-01-08 10:32 AM
sv650s curvy- what are the light bulbs behind the speedo/tacho? vzzzbuxt SV Talk, Tuning & Tweaking 2 19-09-07 04:48 PM
