#11 |
The stock SV crank is engineered to 90hp. As Northwind said, going above that require some serious cash to be thrown at it.
I've done the simple mods of, slip-on pipe, stage 2 jet kit & filter and the '03 inlet cam swap. My bike has been dynoed with 76hp at the rear, an increase of 25% from where I started. All this was on the same dyno too. Cost is fairly negligible compared to what some have done and rideability has been maintained. ![]() Specs for the fuelling with the cams are: BMC 205/10R filter, mains 160fr &157.5rr (Mikuni), Needles shimmed on bottom clip (Mikuni).[/img] |
#12 |
The Sick Man
Is much work needed to put K3 cams into a K2??? Is it just a swap over or does anything else need to be changed?
Is is just K3 cams or also K4 & K5 ones?
OTR: KTM 690 Duke R 2015 Full Akro SIDELINE: Kwak ZX636 A1P 2002, Red, R&G's, Yoshi, Double Bubble Screen GONE: Kwak ZX-7R P1, Full Akro, Undertray, Screen GONE: SV650S K2 Very Bruised & Without Fairing, Motovation Frame Sliders, R&G Ally Sprocket Toe Protector, HEL 2 Line Setup, GSXR K1 600 RWU Forks, Barnett Clutch & Springs, Penske 8981 Shock, Gilles Ti Rearsets, Steel Barends, Scottoiler, AFAM Chain & Sprockets, Twin FIAMM Horns, Skidmarx Bellypan, Full Micron Zeta Steel System, Cut down undertay. Forum Problems & Information / Site Suggestions |
#13 |
It's pretty straightforward... It's been covered before, but basically you need a pair of K3 intake cams (I'm sure K4 and K5 is the same) and a pair of cam chain tensioner gaskets. Some would replace the cam followers (is that the right word? The thing that the cam actuates against to move hte valve) but I didn't. (the reasoning for this is that like chain and sprockets, you get matched wear on the cam and the, er, things. But it would add a lot to the cost to do this, and tbh I don't consider accelerated wear on the cam to be a concern in an SV engine, since they're good for 100K+ miles no problem.
There's a lot of good writeups out there, and on SV Rider- probably best to go straight to the source rather than get my 3rd-hand chinese whispers version. But £130, one evening in the garage, doesn't get better than that as far as power mods on an SV.
Trading sv650 for sv650 sport?? | Wycombe Dave | Bikes - Talk & Issues | 12 | 24-08-08 10:26 PM |
Difference b/t US SV650 & UK SV650 | rc-svs | Bikes - Talk & Issues | 3 | 01-07-08 08:05 PM |
G-PACK for SV650 SV650S SV 650 SV650 S - EFI MODELS - Timing Retard Eliminator | ThEGr33k | SV Talk, Tuning & Tweaking | 0 | 25-11-07 12:22 AM |
will a 2002 sv650 s cylinder head fit my 99 sv650? | bugsy46 | Bikes - Talk & Issues | 2 | 07-04-07 04:26 PM |
Will the forks off of a 03-05 SV650 fit a 99-02 SV650? | Clarker | SV Talk, Tuning & Tweaking | 3 | 24-05-05 09:30 PM |
