Old 14-03-06, 09:01 AM   #11
Skip
Skip's Avatar
Default Re: Fitting Heated Grips
Originally Posted by Blue_SV650S
Originally Posted by Skip
Can you let us know anyway as I would like to fit some to my curvy...
Hiya, there is an orange wire with yellow trace, conveniently located by the fuzebox (which is conveniently right ontop of the battery under the main seat). It is meant to feed the fan, so a rarely used circuit, lets face it the only time it is likely to be used is in the summer and you won’t have your grips on then!! So no worries about overloading wires etc as you might using the lighting circuit.
Simply splice into the orange/yellow wire and take your +ve feed from there. A twist-solder and tape the 3 ends together will do the trick, but I did mine with a double bullet joint as I have the gear for it. Connect the –ve straight to the battery just below … job jobed … a switched live
Excellent - cheers!
'81 Honda H100A
'18 Honda MSX125 (Grom)
Old 14-03-06, 09:22 AM   #12
Grinch
Cool.. I think I'll be doing that...
Old 14-03-06, 09:30 AM   #13
PoRk ChOp
Originally Posted by Diveboy
Will be this weekend I would think. If not sooner with this weather. Did you get that screen you were after?
No probs mate, give me a shout if you need help. You can come round and fit em in the garage.
With all the excitment of going on holiday I forgot about the damn screen. Doesnt matter anyway as I have to buy a new lid, I got hit by a huge stone and it's cracked my Suomy the thing nearly took my head off too.
Fitting heated grips -Ralph- SV Talk, Tuning & Tweaking 8 24-11-08 11:17 PM
Fitting Oxford heated grips carty Bikes - Talk & Issues 22 13-01-08 10:46 PM
Fitting heated grips rwoodcock01 SV Talk, Tuning & Tweaking 3 02-03-06 09:15 AM
Fitting the heated Grips tomorrow rwoodcock01 SV Talk, Tuning & Tweaking 5 26-11-05 06:05 PM
oxford heated grips fitting? csimmo SV Talk, Tuning & Tweaking 25 01-03-05 09:18 AM
