#11 |
Spindle is this type;
Wheel was defo from a K2 GSXR 600 |
#12 |
Hmmm.. if all the bits are what you believe them to be then it should all bolt up right . The spacer/nut I believe is the same. but the axle is slightly longer
Ok a couple of things to check Measure and post up 1) length of the spindle 2)the length of the shouldered bit. Then after comparing to a known k series axle we may have to go to no.4* 3)What's the distance between the two discs inside surfaces(wheel hub width dimension). *4)If you can , carefully(very) pry out the dust seal the also get the number on the bearing. Just trying to cover all bases but maybe someone has stuck the wrong bearing(heightwise). Cheers Ben ps No. 1&2 probably not the problem to be honest but no harm checking. |
#13 |
EDIT: I just realised I should have a couple of axles(SRAD and K) close by so have fished them out and taken some measurements.
SRAD length excluding shoulder = 178mm 'K' Series length excluding shoulder = 171mm All measurements were taken using a tape measure but would be good enough to show what we have Cheers Ben |
#14 | |
The wheel is defo K2 but from a bike with RWU forks if that makes a diffrence. Will measure my axle tonight. Otherwise they both get trimmed with a angle grinder ![]() I sounds like I may have a SARD axle, but need a K series one, do you want to sell yours if thats the case Ban? cheers Kieran |
#15 |
Personally I would not go trimmimg anything.
It should bolt straight up the question is 'why is it not?' (ok I'm very curious as to why you have a problem ![]() While you are there(curious again) , could you measure the centre to centre measurement of the top yoke where the forks go through ![]() Cheers Ben ps: PM sent |
#16 | |
![]() The axle fits perfectly with the wheel out, it the right length and sits flush both ends! Its when the wheel is in the captive spacers on the axle cause the nut and axle to stick out a few mm each side, to center the wheel properly! The bearings in the wheel, spacer all look fine and properly fitted! The wheel is K2 off a bike with RWU forks not USD forks, but I wasn't aware that should make any diffrence. Will measure axle, yoke, and hub tonight and post. |
#17 | ||
![]() ![]() Quote:
![]() ![]() ![]() Cheers Ben |
#18 |
The Sick Man
One question is, does the brake disks line up in the middle of the calipers easly?
OTR: KTM 690 Duke R 2015 Full Akro SIDELINE: Kwak ZX636 A1P 2002, Red, R&G's, Yoshi, Double Bubble Screen GONE: Kwak ZX-7R P1, Full Akro, Undertray, Screen GONE: SV650S K2 Very Bruised & Without Fairing, Motovation Frame Sliders, R&G Ally Sprocket Toe Protector, HEL 2 Line Setup, GSXR K1 600 RWU Forks, Barnett Clutch & Springs, Penske 8981 Shock, Gilles Ti Rearsets, Steel Barends, Scottoiler, AFAM Chain & Sprockets, Twin FIAMM Horns, Skidmarx Bellypan, Full Micron Zeta Steel System, Cut down undertay. Forum Problems & Information / Site Suggestions |
#19 | |
One of them is slightly warped so will get straightened tomorrow. Its driving me ![]() |
#20 | |
GSXR 750 k4 front wheel axle part. | Caddy2000 | Idle Banter | 4 | 22-12-08 10:56 AM |
GSXR front end insurance question | crashers | SV Talk, Tuning & Tweaking | 9 | 07-02-08 06:39 PM |
Project GSXR front end - FITTED WITH PICS PAGE 2 -56K BEWARE | Khewett | SV Talk, Tuning & Tweaking | 32 | 05-06-06 09:25 AM |
Another GSXR front end question - ignnition | Khewett | SV Talk, Tuning & Tweaking | 14 | 19-05-06 07:29 PM |
Ye olde GSXR front end question... | Brand New | SV Talk, Tuning & Tweaking | 5 | 01-07-05 03:40 PM |
