#11 |
well at the moment i dont want to ride it down thire i want to fix it then take it down to show the damage ... (take it down on monday) as i cant exactly ride it with the caliper scrapeing all over the disk .... do you guys think i should drop the wheal out and lok at the spacers ??
oh and the speedo drive when the dude told me he kinda just said it like it was alreday broken so what chance i got thire ? |
#12 |
This happened to me once, The right hand slider(fork leg) is split with bolts clamping it to the spacer on the axle. In other words it's not actually located in it's correct position.
Lift the front wheel and undo the clamp bolt or bolts and slide the fork leg to it's correct position. You may need to use a straight blade screwdriver to pry the fork leg apart to move it. I'm surprised it doesn't happen more often, and the guys at that tyre shop must be MORONS not to know about something so obvious. |
#13 |
Sounds like a spacer issue, they sound like complete idiots, I would def. be shouting about that, I mean is it that hard to put the wheel back on the way you got it, sound like a bunch of monkeys
#14 | |
![]() job sorted ta ![]() |
Stressed? Living in the London area? | Cazza | Soho Massive | 17 | 20-02-09 03:47 PM |
Stressed out...test on Thurs!! | LouLou | Bikes - Talk & Issues | 16 | 04-07-07 12:44 PM |
For all you stressed out London / SE Englanders... | Cazza | Idle Banter | 0 | 06-04-06 08:42 PM |
