#11 | |
![]() I'm just going to leave it as it is. Doesn't bother me too much |
#12 | |
#13 |
Yup, but that's not the DJ Stage 1 kit... That's what you end up with if you take the DJ kit and make it work. (plus, I think the stage 2 kit includes the stiffer springs and the #54 drill bit from the Stage 1&3 kit, you don't get those in the small one) No great shock that I ended up with more or less the same setup by improving the DJ stock 1&3 kit really. (though cheaper)
If I was starting over with a full system, I'd go straight to JHS, it's a great product that. Not sure though, does it cater for slipons? That's why I'd not mentioned it, I was under the impression it was designed for a full system.
#14 | |
![]() Cheers Ben |
#15 | |
The settings in the kit are essentially 'Base' settings, but everyone buys a kit to go faster without having any understanding of what they're getting only that it 'Must' be better. There is a kit for just about every bike on the market, more so they can cover all models than improve all of them and not all bike benefit from them, but they still sell because of what they are. The same way everyone buys Ohlins springs over any other linear spring of the same weight with the same performance and quality. |
#16 |
True. But the DJ stge 1 in particular is, I think, misspecced, and if you do choose to interpret it as being a kit of parts for use with a dyno (ie, you discount the R&D cost) then it's absurdly expensive.
Basically, you get several jets that are ridiculously small, and a poor range of larger ones. I think the largest is 144 or 146, while the smallest is either 134 or 136. That's just daft. That's why my assumption is that it was specced out for the very early, restrictive K&N and never revised.
#17 |
The gains to be had with a stage 1 kit are absolutely minimal. Basically you are making a small "tweak" to make the most of your K&N, or BMC, and aftermarkert exhaust. If you were expecting more, then you're going to be dissapointed and it will still need setting up for best results, either by a dyno shop or by yourself. You can do it yourself if you have heaps of patience and a backside that's reasonably sensative to changes, but I can't over emphasise the need for patience - my carbs have been on and off so many times
#18 |
The Dynojet needles are good, that's the only bit I'd buy, other than that jets are cheaper elsewhere.
Dynojet Kit Suzuki SV650S X-K2 Stage 1&3 | DEJA_Vu | SV Talk, Tuning & Tweaking | 11 | 04-02-09 12:01 AM |
Stage 1 ,3 ect jet kits....stage 2? | Torn-Thorax | SV Talk, Tuning & Tweaking | 11 | 05-03-07 07:36 PM |
who has JHS stage 2 or factory pro stage 2? | 01 sv650s | SV Talk, Tuning & Tweaking | 1 | 15-12-06 08:12 PM |
stage 1&3 dynojet kit air filters | 01 sv650s | SV Talk, Tuning & Tweaking | 11 | 13-12-06 08:42 PM |
Dynojet stage 1 and 3 kit contents | northwind | SV Talk, Tuning & Tweaking | 5 | 03-12-04 08:51 AM |
