#11 |
I would only move them a few millimetres (away from the tank). I'd make sure they didn't touch the fairing at full lock, too. I was just wondering about safety. I don't think aftermarket yokes/bars have this feature (anti-rotation casting blob thingy): it's just Suzuki belt and braces policy. I would loctite the threads to prevent loosening and accidental rotation under braking.
Jon. |
#12 |
but if u move them forward the back will kick out and the scre wont fit!? will it..
i am talkin curvy!.. maybe yours is diffo..
ooops I did it again ... new bike . cb1000r |
#13 |
another way is to get bar extenders to take the strain off of your wrists..
#14 |
If anyone has particular hassle witht he SV bars as they are there are always people like heli bars out there with add on stuff http://www.helibars.com/proddetail.php?prod=HB2603
1 1/4" taller 1" rearward 1 1/2" wider Retains stock cables and hydraulic lines. I'd recommend people try the rotating mod first though! $250 ain't cheap. |
#15 |
rotating the levers did it for me - but just as inportant make sure your not tightening your wrist straps on your gloves/jacket too much - restricting the blood flow to your hands will give the same problems.
#16 |
I carefully sawed off the aluminium castings, by taking the blade off a hacksaw, rotating the blade attachments through 90 degrees, passing it under the yolk, and re-fitting the blade. Then I very carefully sawed of the castings, watching that I wasn't sawing off clutch cables, etc. On the throttle side, I had to tape up the brake hose and throttle cables to prevent damage. I also taped up the side of the tank to prevent scratches. When I had sawed off the castings, I loosened the clip-ons, and rotated them forwards till they touched the pinch bolts on the yoke. I put some Loctite on the threads, and tightened the clip-on pinch bolts. Took it for a road test. OMG it's so much better! I can't believe I waited for so long to do it. My wrists feel much better, with the weight carried evenly across the palms, and the bike steers so much better, with more leverage on the bars. The bars don't foul the tank or fairing. Pics attached.
Jon. ![]() ![]() |
#17 |
That will give you a lower riding postion so you'll be complaining about having a bad back next
![]() ![]() ![]() Good mod let me know how you get on. I think moving the leavers will do it for me though. Thanks to everyone for there suggestions. |
#18 |
Those Heli Bars look like a good idea. Anyone tried them?
Jon from Bristol |
#19 |
Got Heli Bars fitten to mine, make a big difference in riding position but I was still gettting numb wrists until I fitted gel inserts to my gloves / played around with lever position.
#20 |
bizarrely when I changed from winter to summer gloves the other week when it got hot (I get very cold hands...
![]() Glad I'm not the only one with a numb little finger ![]() ![]() |
right hand goes numb | jans1971 | Bikes - Talk & Issues | 30 | 30-09-08 11:28 AM |
Numb Nuts!! | sisk650k4 | Pennine Massive | 7 | 23-03-08 10:58 PM |
Numb fingers | Ed | Idle Banter | 6 | 10-05-07 02:46 AM |
owwww my wrists! | remf179 | SV Talk, Tuning & Tweaking | 25 | 24-04-07 11:13 AM |
SV wrists | Special Mike | SV Ecosse | 12 | 10-03-07 10:08 AM |
