27-06-06, 03:25 PM | #11 |
Thanks Sid - I specifically asked him about this "should these come with rubber grease and don't I specifically need that" and he said just to use brake fluid
So should OEM Suzuki seals come with the grease? Edit: also just wanted to confirm the clamps you mention above - do you mean the yoke clamps or axle clamp? |
27-06-06, 03:28 PM | #12 |
I suppose you'd say it's not essential... Just a very good idea. Frost's will sell you a tub for about a fiver that'll last you for 5 lifetimes
27-06-06, 03:40 PM | #13 |
Confused it with my last bike and thought you might be referring to the lower headstock
27-06-06, 04:10 PM | #14 |
Hmm, not getting much joy doing that Sid - I don't know if you can see from that pic above but the axle bolt still sticks out around 4mm so that maybe the problem.
Would this just need tightened more? (I think I'd tightenened it to the recommended torque ). |
27-06-06, 04:19 PM | #15 | |
The Sick Man
Now this is the way i found out mine was damaged, someone may dispute this method, but it worked for me, plus if it is bent and you only want a temp fix then you can find out how much rotation of the top tube will give the correct clearance you need to stop the brakes touching the disk. Usual care should be taken with tighening all bolts prior to riding the bike and making sure no parts are binding. If you are not clear on any of this then leave it to a garage to do.
OTR: KTM 690 Duke R 2015 Full Akro SIDELINE: Kwak ZX636 A1P 2002, Red, R&G's, Yoshi, Double Bubble Screen GONE: Kwak ZX-7R P1, Full Akro, Undertray, Screen GONE: SV650S K2 Very Bruised & Without Fairing, Motovation Frame Sliders, R&G Ally Sprocket Toe Protector, HEL 2 Line Setup, GSXR K1 600 RWU Forks, Barnett Clutch & Springs, Penske 8981 Shock, Gilles Ti Rearsets, Steel Barends, Scottoiler, AFAM Chain & Sprockets, Twin FIAMM Horns, Skidmarx Bellypan, Full Micron Zeta Steel System, Cut down undertay. Forum Problems & Information / Site Suggestions |
27-06-06, 04:23 PM | #16 |
right i had the same problem but mine happened when i changed my tyre!
what it is is the front spindle... ( i think thats the right name) but the bar that goes through the center of the wheal is out of line what u need to do is undo the wheal and the two bolts on the bottom tap the bar through a little (to the left when sat on the bike) do the wheal bolt up and then the two smaller ones ... thats what they did to mine when it happened to my brakes just a thought lol |
27-06-06, 04:24 PM | #17 | |
The Sick Man
27-06-06, 04:26 PM | #18 | |
The Sick Man
27-06-06, 05:31 PM | #19 | |
The Sick Man
27-06-06, 06:37 PM | #20 | |
The Sick Man
Brake light probs | Baz | SV Talk, Tuning & Tweaking | 9 | 24-09-08 08:07 AM |
reg rec probs maybe | dizzyblonde | SV Talk, Tuning & Tweaking | 4 | 27-09-07 04:07 PM |
more probs | hovis | Idle Banter | 6 | 02-10-06 09:05 AM |
Front brake probs, advice needed. | Dirty Baz | SV Talk, Tuning & Tweaking | 14 | 21-03-05 04:18 PM |
sticking brake pt 2 (got some lovely pictures ) *update* | Warren | SV Talk, Tuning & Tweaking | 18 | 24-01-05 04:59 PM |
