Old 13-07-06, 11:48 AM   #11
BillyC
BillyC's Avatar
Originally Posted by Kate
(well, until it was written off anyway)
and even then it was still an SV, and probably even lower!
Old 13-07-06, 05:23 PM   #12
Wadda
The offical Suzuki 10mm lower seat is only £28 for the K4 onwards.
Old 13-07-06, 05:36 PM   #13
Jabba
Originally Posted by Skip
Originally Posted by Jabba-the-Hutt
as the owner of a Hornet (so my taste in bikes is unquestionably bad )
Just corrected that for you Jabba...
Will I never learn.....?
Old 13-07-06, 10:13 PM   #14
xrphil
just out of interest why would she need to get both feet flat on the ground?
one is ok, or front of foot on both, I have to hang off my XR400 to get one flat on the ground.
i did cut an inch out of the foam on it, which made a big difference.
sure she will be fine with either.
have fun.
Old 13-07-06, 10:59 PM   #15
stewart-250
Firstly thank you all very much for the advice. It's very much appreciated.
In response to the last question. She doesn't absolutely need both feet on the ground but it would be good, partly for general confidence but mainly because the exit from our (small cramped) garage is down a really steep driveway which would be a bit scary to roll down backwards if you could only get your tippy toes on the ground. We also like doing a bit of touring and the whole balancing half off the seat becomes a bit trickier when paddling across a muddy campsite in the pouring rain with the bike overloaded with luggage.
She currently rides a Guzzi V50 which is small enought to put in your pocket and has a mega low seat height.
cheers
Stewart
Old 15-07-06, 06:07 PM   #16
Kinvig
Safer to be able to get both feet on the ground!!!!
I stopped at a set of lights & didn't see the pot hole - nearly dropped my bike in front of all the shoppers at Sainsbury's (
Old 16-07-06, 10:59 PM   #17
Stu
Trinity
Stu's Avatar
Surely the answer is Suzuki's 4 years extra development that went into the pointy as it's a newer design makes it better...end of!
Old 17-07-06, 01:33 AM   #18
Nah... They designed in some more problems and didn't get rid of any of the old ones (well, apart from the clutch cover oil leak, which they replaced with cunningly not being able to change the clutch plates without dropping the coolant and replacing a more expensive gasket) They did improve the oil starvation issue, mind.
A lot of the changes weren't improvement-led. The fuel injection was for emissions and budget, not for performance (and it shows) and the frame was redesigned for reasons of fashion and economy (the original frame was the most expensive mass produced frame Suzuki had ever made when it was launched!) The rod design was changed to simplify the machining, but now they're just slightly weaker. Stuff like that. And lets not talk about the paint
There's some definate evolution... The oil starvation thing was good progress, the cam change was well done (performance without drawbacks is always nice), the shift star in the newer one is a better design so less false neutrals, and the forks are a little better. Makes it more or less a tie. If you suffer from and hate carb icing, then you'd call the FI an improvement. If you're happy to use fuel additives in winter as a payoff for the better response and ease of servicing of the carbs, then you'd not (ie, me) but that one shares the honours I think.
Old 17-07-06, 02:07 PM   #19
Stu
Trinity
Stu's Avatar
Well at least I got you an answer from Northy, which is about all you can ask for on a technical point.
Now if someone will just point him to my question on exhausts...
Old 17-07-06, 06:13 PM   #20
Where is it? I shall come and pour scorn on you in your thread too
Why did you choose a naked? or Why did you choose a faired? Magnum SV Talk, Tuning & Tweaking 50 18-03-09 10:47 PM
Best Sv 2008 Round 2 Pointy John 675 Photos 37 04-03-08 12:19 PM
Best Sv 2008 Round 2 Pointy John 675 Photos 2 29-02-08 11:49 AM
Finally decided on a 650.... now which model to choose Mervalous Bikes - Talk & Issues 29 03-01-07 04:58 PM
pointy or round keithd Idle Banter 34 18-02-05 04:43 PM
