Old 23-08-06, 01:46 PM   #11
Richie
fantabulas
Richie's Avatar
Originally Posted by jambo
My vote's still with the foot peg being gummed up with crud.
:Edit: Take the foot peg assembly appart, clean, re-grease & assemble.
Thank you for you info Jambo, this did happen to mine at the end of last year, and did what you just suggest then, It's not the lever, as that was the first thing I checked when I go home.
cheers again.
Richie Numbers
My Flickr photos
Old 23-08-06, 02:43 PM   #12
mudge32
Originally Posted by Peter Henry
Rich,
When you quit the army maybe you should consider a job as a photographer with Hayne's Manuals?
With the age old quote, after the disassembly photos, of "Reassemble in the reverse order" (or summat like that )
Old 23-08-06, 04:26 PM   #13
Rich, did you take the change shaft out and examine the claws and pins? I can't see anything amiss in the pictures, but I'd certainly look there, and when it was off I'd see if the gears could be selected by manually turning the drum, whilst turning the rear wheel.
Old 23-08-06, 04:58 PM   #14
Richie
fantabulas
Richie's Avatar
I didn't take it apart but examined the pins and claw, it is usual for the claw to skip over the pins when you select a gear isn't it ? yes thats why the return spring on the shaft is for.... ( just talking out loud to myself) , and yes whilst turning the rear wheel thats when I heard a click and got all the gears back.....
Still don't know what was amiss, any ideas.? any how wait to get a new gasket before rebuild..
and also rubbing down my cover to get resprayed in high temp silver paint.
My Flickr photos
Old 02-09-06, 02:53 PM   #15
Richie
fantabulas
Richie's Avatar
Finally got the Clutch gasket yesterday, and bought some Stainless Steel Engine case bolts from fleebay,
Put her back together today and she works fine on the Abba stand.
took her off it and just did a little test around the block...
But the bloody weather is crap so not going for a lenghly ride out today...
My Flickr photos
Old 02-09-06, 04:28 PM   #16
andyauger
Default You should have read this first
http://forums.sv650.org/viewtopic.php?t=42387
What you are describing could probably have been remedied by reading the linked thread.
Old 02-09-06, 11:37 PM   #17
Richie
fantabulas
Richie's Avatar
Default Re: You should have read this first
it was the Claw & pins I suspect, as soon as I took off the clutch cage the claw clicked backinto place.
My Flickr photos
Old 03-09-06, 10:18 AM   #18
Groooooovy Baby!
Pleased it's sorted and all working
Andy: What you describe rarely frees up this problem, I've seen this a number of times and there's sometimes a fix by simply wiggling the lever vigorously, usually it's necessary to get in there though. I suspect the problem is that the parts are stamped and often a bit rough and sharp edged, that and the claw pivots aren't a perfect fit.
Edit yourself across the Gap suzsv650 Idle Banter 5 16-02-09 03:49 PM
Photo for Tara... beware full size photo is 2.5mb big and Wide Richie Photos 27 01-02-09 08:57 PM
thanks for the wishes i got the job!! (edit) hall13uk Idle Banter 72 22-05-06 09:03 AM
<edit> Open discussion on Garmin Quest </edit> biketeacherdave Bikes - Talk & Issues 5 22-01-06 11:18 PM
