#11 |
Had the same problem near the hinge, I wouldn't bother trying to fill the leak if it's substantial. My advice is find a bike breakers... i bought my tank from cheshire slavage http://www.cheshiremotorcyclesalvage...uperbikes1.htm Cost me 80 quid including P&P
#12 |
red 2003 tank on ebay £1
#13 |
Looks like it's all done and dusted now.
Main source was from the feed pipe, the clip for which had come loose. Investigation of this resulted in the tank coming off and the favourite hinge point seepage also being evident. This wouldn't be enough to be noticable with regular use, since the heat from the engine would help it evaporate, but sitting around, it would build up. With the tank off, "Petro Patch" Putty was mixed and applied around the hinge plate, and for a "belt & braces" approach, a standard "Petro Patch" kit was used on top. Once refitted and run for a while, the bike ('99) is showing no signs of leakage. Job done (I hope). Nice one. Cheers, Garry |
#14 |
There's a brand new silver one on Ebay just now, by the way...
#15 | |
Fingers crossed again...... Cheers, Garry |
#16 | ||
#17 |
AAAAAARRRRRRRRGGggghhh!
It's STILL at it - just the tiniest seep though - and the pinhole is visible. Belt and braces technique again - putty (loads) and then a regular patch over that. It's gonna be a slow bike with all the extra weight! Cheers, Garry ![]() |
#18 |
If that was mine, I'd call it a bad deal and get a replacement... Pinholing's one thing but a liner treatment like Petseal should fix that easily. Failing welds, well, you can fix it but you can't remove the cause, just the symptoms. You're going to have an awful lot of patch,and that stuff can be vulnerable to vibrations...
Still welcome to my spare to get it sorted in the meantime while you sort it out... Doesn't look too good but it's not got any extra holes in! I'll not need it again for a few months at least.
Help - Oil Leak. | sprocket | SV Talk, Tuning & Tweaking | 9 | 21-06-07 08:05 PM |
oil leak? | will | SV Talk, Tuning & Tweaking | 4 | 04-03-06 05:01 PM |
Petrol leak update advice please | Quiff Wichard | SV Talk, Tuning & Tweaking | 8 | 09-02-06 01:19 PM |
Oil leak - help! | Warthog | SV Talk, Tuning & Tweaking | 9 | 03-02-06 04:09 PM |
Not oil leak - Petrol leak - double "Bugger"...! | Potts | SV Talk, Tuning & Tweaking | 1 | 17-10-04 08:16 PM |
