Old 13-10-06, 04:02 PM   #11
carlos
I wonder if anyone has tried going the other way with an SV to get higher top end, though it'd probably have the acceleration as my Avensis
Old 13-10-06, 04:04 PM   #12
hovis
if its not broke, dont fix it
Old 13-10-06, 04:46 PM   #13
rob13
taking top end and the acceleration differences away, does this mod make a difference to fuel consumption or chain wear? Do you have to buy a new chain because of changing the sprocket?
Old 13-10-06, 04:49 PM   #14
Razor
You only need a new, longer chain if you're adding teeth to the trear sprocket.
I've had a 14 tooth front sprocket on mine for the summer and it's spot on for the roads and speeds that I use everyday.
Old 13-10-06, 04:50 PM   #15
BILLY
Default Re: Little mod big difference
Originally Posted by skulpt
I have just fitted a 14 tooth front renthal sproket to my '00 svs and i must say it has made a sigificant difference in the acceleration and roll on. Top end is more revey but it was well worth the hassle as im loving it.
Where did you get your 14t sprocket from and how much?
Old 14-10-06, 11:43 AM   #16
carlos
This thread has had me thinking a lot last night, so this morning I've been looking at sprockets on t'internet. Renthal do rear sprockets from the usual 44/45 of the s/naked respectively going up to 49 Why the hell would you want a 49 tooth rear on unless you do hill climb or like your rev-limiter?
Old 14-10-06, 02:44 PM   #17
rob13
power wheelies every time?
Derestriction on the cheap? Im sure it would only manage about 35mph!
Difference Between the R6 and the R6r????????? Mej Bikes - Talk & Issues 11 20-05-09 07:36 AM
Big difference in HP? KillaSV SV Talk, Tuning & Tweaking 5 06-04-08 07:36 PM
An SV with a difference.... Daimo Bikes - Talk & Issues 30 05-03-08 10:34 AM
The difference between our needs. Jester666 Idle Banter 3 05-09-07 01:05 PM
The difference between an R6 and the SV... Ibanez7779 SV Talk, Tuning & Tweaking 37 23-10-04 01:59 PM
