#11 | ||
#12 |
Marshall's sorted for pins
![]() I've got a Mityvac and a Big Syringe, I only use the Mityvac for draining lines now. I prefer to us the syringe to push fluid- bubbles want to go up, so it works well to make the fluid go up as well. I've got a bleeder on my master cylinder which makes things easier still. Go Big Syringe!
#13 |
Morning all.
Just remember that when using a Mity-Vac, or a syringe, it really helps if you remove the bleed nipples & carefully wrap a few inches of PTFE tape around the threads before starting to suck or blow MATRON!! This will prevent air from being drawn down the threads. Also make sure that you don't block the holes in the nipple, and that you wrap the tape around the threads in the correct direction, otherwise the tape will 'unscrew' when you screw the nipple back in. Cheers. |
#14 | |
zx600r rear 'break' question, (rear brake). | steve.s | Bikes - Talk & Issues | 6 | 19-02-09 07:50 PM |
WTD - rear brake lever, front brake lever, r & G crash bung, | nik_nunez | Stuff Wanted | 0 | 17-10-08 08:27 PM |
Front Brake - Rear Brake? | Stradders | Bikes - Talk & Issues | 35 | 17-09-08 04:44 PM |
Cleaning all around the rear wheel / swingarm / rear brake caliper | Camel | SV Talk, Tuning & Tweaking | 12 | 28-04-08 02:00 PM |
Brake light not working when rear brake is used.. | StreetHawk | SV Talk, Tuning & Tweaking | 10 | 16-04-07 03:40 AM |
