#11 |
I suppose if Suzuki didn't use cheese the torque settings might be higher.
Pete |
#12 |
Hi Kev, have you thought about the IAM yet?
You get lots of input riding wise PLUS workshop sessions if you need it........ ![]() Happy xmas to you too by the way........YOU SURVIVED ![]() |
#13 | |
Ensure engine is warm so that oil runs freely. (10 minute drive will do it) Put oil catcher under sump and remove plug. Remove oil fill cap to let oil flow freely. Use oil filter spanner (about £5 from Busters) to remove oil filter. Let oil drain out. Clean round sump hole and oil filter flange(say that p*ssed!). Smear engine oil round oil filter seal and screw oil filter in - screw in until rubber seal contacts mating surface and then two full turns. Replace sump plug.(21 NM) Fill with 2.4 litres of new engine oil. Replace filler cap. et Voila' |
#14 |
Mine normally go something like this:
Ensure engine is warm so that oil runs freely. (10 minute drive will do it) Put oil catcher under sump and remove plug. Spanner slips on rounded nut and skin knuckles Burn hand on hot oil and drop sump plug into oil drainer. Remove oil filler cap to let oil flow freely Splash oil all over garage floor. Try and remove oil filter by hand, slip and skin knuckles. Use screwdriver and hammer (to tight to buy oil filter spanner (about £5 from Busters)) to remove oil filter. Splash oil all over garage floor Clean round sump hole and oil filter flange. Smear engine oil round oil filter seal and screw oil filter in - screw in until rubber seal contacts mating surface and then two full turns. Replace sump plug.(21 NM) Fill with 2.4 litres of new engine oil Slip with funnel, splash oil all over garage floor Replace filler cap. Clean garage floor ![]() |
#15 | |
#16 |
Will all the oil drain if the bike is on a (NWS) stand?
Do loweer fairings need to be removed? thanks |
#17 |
i always drop the old oil out and pour fresh in so it runs straight through and out the other side again just to make sure the sump is clean.
#18 | |
'Rupert' !!!! ![]() John. |
Changing from S to N | drinking | Bikes - Talk & Issues | 13 | 22-05-09 02:14 PM |
Changing the Oil | stephen365 | SV Talk, Tuning & Tweaking | 17 | 18-08-08 07:09 PM |
Changing your oil? | Moffatt666 | Bikes - Talk & Issues | 0 | 02-01-08 05:17 PM |
Changing your (real) name | Ed | Idle Banter | 30 | 07-12-07 03:30 PM |
changing down | alex.j | SV Talk, Tuning & Tweaking | 8 | 05-04-06 01:10 PM |
