#11 |
how about, open your throttle harder, change the sproket ratio, and remove the manufactures ignition retard in 2nd and 3rd
#12 |
This is correct in my opinion, thats all that the G-Pack does. I will admit that I have a G-Pack fitted, but before you say anything, I paid £0 for it from a breaker.
#13 |
I did it on mine (with the wire removal) and tbh I didn't notice the slightest difference. So then, I removed the wires entirely resulting in a weight saving of at least 30 grams, which of course I also didn't notice
#14 |
You won't because the SV is only very slightly retarded, anyone says they can then it all in there head to be honest!
Here is a dyno print out, as you can see it isn't a difference you are gonna feel with your **** dyno. ![]() |
#15 |
Have done the freebie wire mod on mine. Connector box is located under the tank. Free the couple of wires correctly and you can always put them back.
Did it to a few other guys Sv's as well. Some felt a difference (allegedly) and some didn't. I reckon a lot depends on how you open the throttle. ![]() |
#16 | |
is that dyno 65.6 with out the wires done then 67.1 with the wires cut? ![]() |
#17 |
TBH that's within the margin for error, it makes more sense to look at the shape than the numbers.
#18 | |
![]() There is not a 'restriction' in the lower gears, it done for smooth delivery, if a glitch is put in the bike will feel quicker as there is a big change in power, but in truth it'll probably make less if you can feel it (not that the TRE works at all, the only time its handy is for loosing speed restriction on other bikes) Its like a badly jetted bike, if there's a dip in the midrange the power will climb faster than on a correctly jetted bike, so the difference is bigger making it feel quicker. |
#19 |
Nikko g pack??? | skapegoat | SV Talk, Tuning & Tweaking | 17 | 31-01-07 12:24 PM |
nikko g-pack | 01 sv650s | SV Talk, Tuning & Tweaking | 10 | 19-12-06 07:19 PM |
Nikko G-Pack for K3 Sv650 | Khewett | Stuff Wanted | 0 | 30-06-06 10:56 AM |
nikko electrics | andy marriner | SV Talk, Tuning & Tweaking | 3 | 14-11-04 11:13 PM |
Nikko Racing | wheelnut | Exhausts | 0 | 18-05-04 09:57 AM |
