Old 08-02-07, 03:40 PM   #11
Ceri JC
The basic service – we train and help you
1. Oil – drain and replace
2. Oil filter - replace
3. Plugs check, clean, regap or replace
4. Chain – clean, degrease and regrease, tension
5. Electrics – check, improve or repair as necessary
6. Fault diagnosis – we won’t promise a fix, but you’ll know what to ask your garage to do
7. MOT pretest – before you leave we show you what the tester looks for
8. Gearbox/driveshaft - oil change
9. Air filter - clean or change
10. Fastenings checked, replaced, greased or locked, tensioned
11. Brakes - dismantled, bled if required, checked, cleaned, refitted
12. Cables - checked, oiled, retensioned
I would be most suprised if you completed a 12 week bike maintenance course at nightclass and weren't comfortable doing those things (and a lot more). I can see how if no other options were available this would be tempting. For £250 though, I'd want someone to show you how to get the forks out, take off the swing arm, wheels off, clutch change etc. perhaps even a valve clearence check/adjustments and switching out engines.
Old 08-02-07, 03:49 PM   #12
Baph
Originally Posted by Ceri JC
For £250 though, I'd want someone to show you how to get the forks out, take off the swing arm, wheels off...
I got that (plus all the things they're offering at £250, which isn't an awful lot) and a little more, for £175, including all parts.
I didn't get that though
Old 09-02-07, 07:46 AM   #13
Dave The Rave
where did you get that then?
Old 09-02-07, 09:27 AM   #14
Baph
Spanner Man www.stewartsmotorcycles.com
See my wee write-up here.
Old 09-02-07, 09:42 AM   #15
Ceri JC
It's http://www.stewartsmotorcycles.co.uk/ (.co.uk, not .com.)
Old 09-02-07, 10:02 AM   #16
Baph
Old 09-02-07, 11:47 AM   #17
Dave The Rave
hm ... that's round the corner from me ....
Old 09-02-07, 12:10 PM   #18
Baph
Yup, worst case, down the A6, A623, drop straight to M1 J28.
That was my route home Give him a call, discount to .org members
