Old 22-02-07, 01:28 PM   #11
Mogs
Default Re: What's in the tool kit?
I've only got the standard toolkit as I have breakdown cover i would prefer to be rescued than mess about. I do however have a disposable camera and a first aid kit.
Old 22-02-07, 02:28 PM   #12
Ceri JC
This might be worth considering if you're building one from scratch (rather than building it from tools you already have).
HTML Code:
http://www.insidebikes.com/bikebuys/showcase/product/product_detail.asp?prodid=560
All I'll add to what the others have said is; There's little point carrying tools you don't know how to, or aren't prepared to use. If you're going to be relying on a mechanically competent kindly soul who stops to help, they'll probably have the necessary tools on them anyway (unless they're in their car!).
Old 22-02-07, 08:16 PM   #13
xlewdx
Hey Guys....thanks a million! All the replies and comments have been really helpful cheers.
With all your help I think I can now actually put together a few essentials nice one.
Old 22-02-07, 08:25 PM   #14
mattSV
mattSV's Avatar
Originally Posted by lawsonium View Post
Ok, I have only ever had punctured tyres replaced on my bike. What exactly does a puncture repair kit for a tubeless tyre consist of and how do you administer it on the side of the road?
Matt.
IIRC correctly, the order of use is something like this:-
1) Insert spikey hook thing into hole and ram in and out a few times (oooeeerrr) to roughen up the edges.
2) Smear the spikey hook thing with glue and insert in to hole again to spread the glue around
3) Smear the rubber loop with glue
4) Hook the rubber loop onto the hook and insert 3/4 of the way into the hole
5) Cut of the excess on the outside of the hole
6) Connect the gas canister
7) Re-inflate and ride home
You do get instructions in the pack - i had never used one before, and managed to repair a tyre that was already several miles past it's 'best before date' and then ride 300 miles home with no problems whatsoever.
For years the REP&AIR Tubeless Tyres Kit (Motorcycle Puncture Repair Kit) has been part of the original equipment supplied by BMW. It provides a system to seal motorcycle tyre injuries without demounting the motorcycle tyre from the rim.
SAFETY INSTRUCTIONS: Have the motorcycle tyre checked/replaced/repaired by a motorcycle tyre specialist after max 400km (maximum speed 60km/h).
The kit for tubeless motorcycle tyres consists of:
3 x cartridges each 16gm
1 x adaptor
3 x super sealistic repair plug
1 x special cement BL tube
1 x inserting tool
2000 - 2004 SV650S
2004 - 2009 SV1000S
Old 22-02-07, 08:27 PM   #15
fizzwheel
fizzwheel's Avatar
Matt you've missed step 8 of that list
8. Get the p*ss ripped out of you, by myself, Scoobs and Liz whilst attempting to fix said puncture.
Under mine is normally, Waterproofs, Puncture Repair kit, Basic Suzuki tools
Old 22-02-07, 11:50 PM   #16
lawsonium
MattSV, thanks. I'll investigate purchasing some.
Matt.
Old 06-04-07, 06:43 PM   #17
biccy_boy
Cool Re: What's in the tool kit?
Hi guys,
fantastic list of tools !!
Can anyone hep me to soure the Oe spark plug spanner please. What size is it and how long does it need to be to get in there - I didn't get a toolkit with mine and now need to service bike following 6 month storage period...
Mark
Old 06-04-07, 10:44 PM   #18
svrash
Make your own
Theres more stuff under my seat, do a search as loots of people have asked the question and theres been lots of good ideas
Old 09-04-07, 05:39 PM   #19
biccy_boy
hi svrash,
plug wrench is the sticky point - they rarely come up on ebay so was looking for help sourcing an alternative such as a long reach socket or box wrench. Problem is it looks tight in there and my 16mm sockets don't seem to fit (CR8E plugs are 16mm hex size aren't they ?). Also suspect that a thin walled wrench is needed too.
Reason I need this is that my bike wont turn over after a few months of non use, tried battery etc but want to turn over now with no plugs in and a drop of oil to see if semi-seized....eek.
Old 09-04-07, 09:19 PM   #20
svrash
I brought a plug socket from halfords for my main tool box, fits llike a glove
k3 tool kit blueto Stuff Wanted 0 26-02-08 03:50 PM
'04 SV Tool Kit BLK SV For Sale - SV's and SV related items 2 24-01-08 08:46 AM
SV Tool Kit/Spark Plug tool svdemon Stuff Wanted 1 17-12-07 12:29 PM
Er....yes, it's a tool :) 21QUEST Photos 14 13-08-07 11:48 PM
Tool Help Ceri JC SV Talk, Tuning & Tweaking 6 09-06-06 11:07 AM
