#11 |
I think Northy was saying..."On standard SV's putting 4-pots on could cause you more problems than it solves."
In your case though, you already have good front end upgrades to make the most of them. Remember a pair of 4-pots may require a new master cylinder to match, other wise that extra 'feel' you're after might not materialise. |
#12 |
Yes I know what Northwind and others are saying. I just don't think(now) that's so much the case
![]() I think the SV calipers work good myself as never really had a problem stopping but they are a pain in the proverbial(for me) to keep them working good. Ben ps: The GSXR use the basically the same master cyliner I believe. |
#13 | |
Maybe down to personal preference, but if you're going to undertake this project I'd certainly factor in the possibility you'll need a new master cylinder. |
#14 |
They are the same Master cylinders, perhaps you had an airlock you couldn't shift?....
#15 | |
#16 | |
Bore(5/8 ) is definitely the same. The SV1000 I think uses a slightly smaller or slight larger bore though(can't remember). The GSXR1000 K3/K4 actually uses a 14mm bore master cylinder. Of course the bore is only one aspect in the equation. I really don't think a master cylinder change would be a neccessity. Maybe your SV master cylinder was not in good shape ![]() Ben |
#17 | |
Ben |
Front Brake - Rear Brake? | Stradders | Bikes - Talk & Issues | 35 | 17-09-08 04:44 PM |
K3 front brake lever, Front indicator (RH), Front Mirror(RH), Bar End (RH) | leegriffiths128 | Stuff Wanted | 0 | 23-07-08 09:11 PM |
front brake disc question | Ryest | SV Talk, Tuning & Tweaking | 5 | 31-10-07 09:02 PM |
Front brake not activating brake light properly | SVeeedy Gonzales | SV Talk, Tuning & Tweaking | 5 | 27-02-07 12:09 PM |
brake light flickers when the front brake pulled in - K4 | dclifford | SV Talk, Tuning & Tweaking | 9 | 05-09-05 10:39 AM |
