Old 17-03-07, 12:17 PM   #11
21QUEST
21QUEST's Avatar
Default Re: Adjusting r6 throttle
Originally Posted by 01 sv650s View Post
i put the standard one back on and it returns so f**k knows why the r6 throttle wont retun
This might sound like a silly question as already been mentioned but have you adjusted the cable slack properly.
If you can't get the correct adjustment then you may have to do it at the carb end. For you to be able to get the correct adjustment at the throttle tube end depends on how much initial slack was at the carb end.
Someone might have worked on the carbs previously and put the ajustment(with original tube) at basically almost the bare minimum using the carb end adjusters.
Put in the R6 tube and you don't have sufficient adjustment at the throttle grip end.
Anyhoos I reckon that is what the problem is. To get to the cab end adjusters, airbox has to come off.
Ben
Nemo me impune lacessit.
Old 17-03-07, 02:26 PM   #12
NedSVS
Put the R6 throttle tube back on without the cable attached and check it rotates freely. If it does, then it must be cable related.
Needed: An Idiots Guide to Adjusting Throttle Cables Steve_God SV Talk, Tuning & Tweaking 4 16-01-08 08:06 AM
adjusting speedo 01 sv650s SV Talk, Tuning & Tweaking 4 27-02-07 11:18 PM
Adjusting suspension on the 06 SVS Kawyamonda SV Talk, Tuning & Tweaking 4 20-02-06 01:01 AM
Adjusting Clutch echomadman SV Talk, Tuning & Tweaking 5 16-05-05 03:41 PM
adjusting the headlight Lolo SV Talk, Tuning & Tweaking 3 31-01-05 09:18 PM
