Originally Posted by yorkie_chris
While we are on the subject of these here electricals, I have double headlights fitted, so the 2 wiring connectors, one black and one green IIRC, are on display below the lights, which I don't like the look of so am going to try and move them to inside the frame.
Can the wires be removed from these connectors to splice in some different lengths?
Where to buy small amounts of various coloured braided wire? What gauge to use?
And also where to buy heatshrink tube to seal the connectors?
Apologies for double post and the question barrage.
Chris
Yes you can remove the contacts if you want, but you'll strugle without the proper tool. You could look at cutting the wires and "inserting" an extension wire. This should give you enough length to move the connectors out of site, and keeps everything standard. Just buy some inline crimps from any electrical store, or even Halfords, B&Q etc. You'll get wire & heatshrink from the same place. Just make sure you use a proper crimp tool with them. Not sure what size this cable needs to be, it all depends on the load, i.e. how many Amps are flowing in the circuit. Try and match the cable size to what's already there. If your not sure 1.5mm wire
will probably be big enough. It doesn't do any harm if the wire is bigger than required, but you can make a fine old mess if the wire is too small.
