Old 25-08-07, 04:20 PM   #11
PaulSV650S
Default Re: Removing the mudguard - front wheel off?
are you concerned about the rubber brake line and speedo cable being exsposed that hover inches above the tire????
Old 25-08-07, 06:49 PM   #12
svdemon
I've just started taking my 03's front end off and the second allen bolt has just rounded instantly! Is there someone out there selling proper bolts for suzukis?
These chocolate ones just aren't up to standard!
Old 26-08-07, 08:18 AM   #13
Tiger 55
No. Should I be?
I'm not planning on riding around without it mate, just whipping it off to get the fork-eating gunge out from under.
Demon - Chewy sells proper bolts for Suzukis at Chewy's Stuff
Old 28-08-07, 08:57 PM   #14
Birchwood
You got a Haynes for a K6, i can not find it even on the Haynes web site, and they have not answered my question !!
Old 29-08-07, 10:54 AM   #15
Neil63
Oddly enough I needed to take off the front mudguard for my K6 this weekend to fit a Fenda Extender.
It's easy. Just undo the outer threaded screws with an Allen key then reach in with a 10mm socket and deal with the two inside bolts. Fiddly but not difficult.
Putting it back on is just the reverse except I first located the mudguard with the outer bolts leaving them finger-tight, tightened the inner bolts and finished off the outer bolts last. Voila.
Cautionary word though: the previous post from svdemon warning about rounding the bolts with an Allen key is on the button - make sure you have exactly the right size Allen key and be gentle when you loosen or tighten. Unfortunately this is a risk with stainless bolts and screws - they don't have the same hardness as other types of steel but at least they won't rust!
SV650 Front Wheel - Do any other Suzuki models use the same front wheel? williamturner1 SV Talk, Tuning & Tweaking 11 30-05-10 02:31 PM
Removing the rear wheel gilby104 SV Talk, Tuning & Tweaking 20 26-09-08 08:27 PM
what to do with the belt when removing the rear wheel on a buell kwak zzr Bikes - Talk & Issues 4 15-11-07 09:00 PM
front wheel maintenance ?? need to prop up front wheel etc valleyboy SV Talk, Tuning & Tweaking 2 26-08-05 07:50 PM
Removing front mudguard to fit extenda branny SV Talk, Tuning & Tweaking 10 10-08-05 12:37 PM
