09-10-07, 11:37 PM | #11 |
Re: Gen 1 w/zx6 shock, 05 GSXR forks, notes & question
the 2046 kit is a 2040 kit with rebound rod extenders, nothing more.
im running basically the same setup (without extenders and got ohlins rear) on a carby you want as much height as possible for ground clearance, you'll struggle to make it unstable. the rear shock is on max height with shorter links and the forks are flush. you'll run out of side grip with a 120/60 tyre, basically by going off the edge of it. 12st rider i run .85 springs 25mm static sag c34 stack with digressive 110 airgap with us1 handling is nigh on perfect and plenty of mid corner rear grip. i dont think the extenders will be as effective on the later forks as they have a long topout spring, hence you measurements are similar to std. oh and loose the steering damper, you'll notice the initial turn in is better and also in the wet. has he moved the bottom out plunger or just drilled the housing? The G2r valve is better but a bit harder to setup btw |
10-10-07, 12:57 AM | #12 | |
Loose the damper you say. I'll give it a shot, hate to loose my major bling-bling. He says there was no drilling involved. I don't know enough about the fork guts to answer any more inteligently than that. On a personal note - RobW: How much do you weigh, and is your sister good looking? All very interesting. You guys are saving me steps. Thanks for help. Last edited by JuicyGuzzi; 10-10-07 at 09:49 AM. |
10-10-07, 01:00 PM | #13 | |
10-10-07, 03:00 PM | #14 |
12 st= 172 pounds
HTH
10-10-07, 09:43 PM | #15 | |
The length on the ZX6 shock comes from actual measurement and direct comparision side by side with the stock SV shock. I put a bolt through the eyes of both shocks together. At 333 mm the ZX6 shock was 4mm shorter than the SV. I can't account for the difference you mention. All measurements taken with a tape measure in inches and converted, so they possibly are not dead-nuts on, however it was all done with care and the numbers are very close or better. The shock works well for me. I recommend it highly for those who would like to get the bounce out and don't mind relocating their battery. Might be too stiff for some riders. Last edited by JuicyGuzzi; 10-10-07 at 11:12 PM. |
Gsxr k6 Shock - quick question *fitted | dotted | SV Talk, Tuning & Tweaking | 8 | 10-11-06 10:07 AM |
Rear Shock... No Dont worry.. not another GSXR question... | 454697819 | SV Talk, Tuning & Tweaking | 7 | 12-04-06 09:52 PM |
GSXR 1000 Shock Question | mikehunt03 | SV Talk, Tuning & Tweaking | 2 | 04-01-06 08:51 AM |
same old gsxr shock question!! (sorry) | SV-DIY | SV Talk, Tuning & Tweaking | 3 | 07-09-05 07:37 PM |
gsxr 1000 shock question - difference between K2 and K3 | will | SV Talk, Tuning & Tweaking | 4 | 20-05-05 07:41 AM |
