Old 14-11-07, 10:01 AM   #11
Alpinestarhero
Default Re: Chain wear
I think at 17k you should be looking at a new chain and sprockets...mine was changed at 18,000 miles and was in a bad way...
Matt
Old 14-11-07, 11:09 AM   #12
Originally Posted by dyziowg View Post
Don't want to start a new thread so I'll post it here.
I gave my chain a clean with B&Q's white spirit (paraffin based) and I've also bought this now.
Effect? Chain is CLEAN, however, it needs frequent adjustment now (every 300-500 miles).
Is that because the stuff I used is cr*p, and has damaged the chain,
The stuffs fine mate, its just not a lubricant!
Chains need oil or grease, just being clean isn't enough.
Old 14-11-07, 11:12 AM   #13
Alpinestarhero
He;s right
get some chain lubricant on there; silkolene and wurth are good, I've used both (prefer silkolene at the moment)
Matt
Old 14-11-07, 11:13 AM   #14
Get a scottoiler
Old 14-11-07, 11:19 AM   #15
dyzio
dyzio's Avatar
Forgot to mention, chain is lubed every week, and after cleaning.
I've been just worried if I damaged the chain or it simply reached it's limit.
I'll probably get a Scottliler with the new chain after the winter sleep
Old 14-11-07, 12:08 PM   #16
I just got 15000 out of an alloy sprocket though, steel with a scottoiler should last at least twice that if it's cared for really.
Old 14-11-07, 01:34 PM   #17
Mine with the scottoiler hasnt needed any attention at all since I fitted the oiler.
Seems to keep itself clean due to the flow of oil, I check tension weekly and it hasn't needed adjusting.
Old 14-11-07, 01:47 PM   #18
dyzio
dyzio's Avatar
yup, new chain & sprockets are on the shopping list, and of course a scottoiler.
So what is the advantage of an alloy sprocket? I assume that they are more expensive.
Old 14-11-07, 02:19 PM   #19
Lighter and look trick
The weight gives marginally better acceleration (mroe than normal weight loss as its a spinning component)
And as its unsprung weight theres a small improvement to handling theoretically.
Mostly they just look trick.
Old 14-11-07, 08:09 PM   #20
Yep, a weight reduction you won't notice, in return for a reduced lifespan. Bit of a mug's game really, but a good one, cared for, will still get more miles than a steel one, not cared for, so I don't really object too much. Steel makes more sense though.
Uneven chain wear rockster SV Talk, Tuning & Tweaking 17 16-05-09 08:03 PM
what do you wear? Wideboy Idle Banter 26 17-05-08 11:11 PM
What makes a chain wear due to lack of oil? muffles Bikes - Talk & Issues 16 09-06-07 09:14 AM
Mixing chain wear tomjones2 SV Talk, Tuning & Tweaking 1 29-04-07 02:26 AM
To wear, or not to wear.. rubberduckofdeath Idle Banter 25 28-03-06 01:15 PM
