Old 25-10-07, 11:56 AM   #11
timwilky
timwilky's Avatar
Default Re: Woop, woop, I did a jump!
Do a North/South
As you come into Hawes from the Ribblehead there is a slight hump. so good people have been known to U turn just to do it again
Not Grumpy, opinionated.
Old 25-10-07, 12:16 PM   #12
hovis
Do a North/South
did we do that this year?
Old 25-10-07, 01:20 PM   #13
phil24_7
Also check your brake pads. They may have slipped or moved due to the impact. I had this happen to me after a big tank slapper so its possible an impact like that could shift them to.
Cheers, will check in a mo.
Old 25-10-07, 01:32 PM   #14
ClemsonSV
Originally Posted by graemepaterson View Post
Why would hitting a plank of wood have to occur on his 'private road', theres nothing you can do about it.
There is a crossroads on my commute that has a weird drop to it, one time when i attempted to get away from the lights quickly i went up the drop and I'm sure the whole bike jumped, i to shat my pants.
He was doing 110 mph....on a private road, not jumping over sticks.
Old 25-10-07, 01:43 PM   #15
phil24_7
I was doing between 90 and 100 through some downhill twisties when I hit said lumb of wood, it now judders from the front wheel when I go above 110. (All on my private road you understand!)
Just glad the wood wasn't in the corner else I probably wouldn't be wrirring about it on this forum!
Old 25-10-07, 03:16 PM   #16
Bluepete
Bluepete's Avatar
Do a North/South
What? Like this?
Old 25-10-07, 07:57 PM   #17
phil24_7
Well, I checked the bike and apparently, 90mph into a chunk of wood DOES bend the rim.
Only bent on one side which means I was leant over a bit so it's even luckier that I escaped without crashing.
The damage doesn't look to bad (2-3" of the rim has been puched in with the worst bit pushed in by about 1-1.5cm) but I still don't wanna be riding on it.
Is is ok to get this bent back into shape or is it not advised?
Anyone know where I should take it to get it done??
Cheers all.
WOOP! ITS HERE...Weekend thread....sponsored by Mothercare keithd Idle Banter 50 04-04-09 01:12 PM
the weekend thread! woop....post plans here. sponsored by willies on the roof keithd Idle Banter 35 27-03-09 11:06 PM
How do you jump? Stu Bikes - Talk & Issues 47 18-05-08 09:32 AM
To jump or not to jump: special red light circumstance MeridiaNx Bikes - Talk & Issues 23 15-11-07 12:59 PM
Can i jump start my bike with jump leads (Like my car!) Freeloader SV Talk, Tuning & Tweaking 3 08-12-05 06:46 PM
