Old 30-04-12, 10:12 AM   #2211
Default Re: The Cycling Thread
What are them old fangled things you've got on your pedals
Get some clipless
Old 30-04-12, 10:48 AM   #2212
EssexDave
Waterproofs are overrated - you will get sweaty and wet (but slightly more unpleasant than rain wet).
Get some overshoes (as wet feet isn't nice) and get on with it. Provided it's not absolutely hammering it down it's not much of a problem!
Old 30-04-12, 11:15 AM   #2213
StewartR
Binned the toe straps in favour of some Shimano 105 pedals + DNB shoes.
I'm odd with rain - Happy running in it, happy chucking motorbikes about in it, just don't get on with cycling in in. Maybe I should man up and go do some serious miles on a rainy day and see if that sorts me. Any recomendations on the overshoes?
Old 30-04-12, 11:28 AM   #2214
H'mm don't mind getting caught out in the rain, but no motivation to start out in the rain.
Overshoes, neoprene are warm, but your feet will still get wet if its really heavy rain.
Some folk cut a hole in a pair of Sealskinz socks to use as a oversock, although you could wear a pair of the thin Sealskinz socks if you want to keep your feet dry
Old 30-04-12, 01:13 PM   #2215
EssexDave
I have some waterproof shoes (Northweave winter boots) which are outstanding at keeping you dry but just so damn warm for the summer.
Overshoes I have Altura ones from Wiggle that were about £20ish. They are a bit warmer but not too much.
You will get wet in heavy rain regardless of what you are wearing.
Old 08-05-12, 04:16 PM   #2216
stewie
Since buying my bike Ive tried to get out as often as possible in between work, family, decorating etc.. anyway I seem to have picked up a bit of a wierd injury, it seems like ive got tennis elbow !, it only started after my first ride in mar and has got steadily worse, I dont know if its cos of me moving around the bars when I first started riding or what, gas anyone else experienced the same thing through riding or is it just me ?
Old 10-05-12, 07:37 PM   #2217
Don't know Stewie, its a bit weird
Possible causes, are your bars the right width? They'll have stuck on a generic size, but that might not suit you?
If you've got wide shoulders, then you'll need wider bars, I'm quite narrow, so I only use 40cm wide bars.
Best way to check is go to your local good bike shop and get them to see which size bar fits, across your shoulders.
plus looking at your bike, the saddle to handlebar height is quite wide, that may be putting extra strain on your elbow joints, so getting a stem that raises the height a bit might help.
are you stretching a long way to the bars, another possible cause of extra strain?
Difficult to know, without seeing you on your bike.
See if there's a LBS who does proper bike fitting if this carries on. There is a network of Specialized dealers who do bike sizing/fitting
Old 10-05-12, 08:14 PM   #2218
stewie
Going to be taking the bike back to have a service done pretty soon so going to have him fit the correcelty, felt ok at first but now thinking its worth checking over, think the seat may be a bit low as well, oh well,need to get some clips sorted out as well
Old 10-05-12, 08:26 PM   #2219
Bikes always feel right first of all. But then you body says I don't like this one bit after riding it in the wrong position for a while.
Having ridden in my current position over many years, I can tell almost instantly if the saddle height has slipped and if I've built a new bike up, if I've got any thing wrong, because the frame dimensions are different.
I don't know what I've done, because I'm having a lot of problems getting my right foot cleat in a position that my outside knee joint likes. I haven't changed the cleat, and it was perfect last year, but these are my summer shoes, which I've swapped back to after riding in my winter boots
But its not right, as I don't feel I can get full power onto the pedal
Old 11-05-12, 09:10 AM   #2220
Luckypants
Luckypants's Avatar
Jeez! Totally knackerd after a 30 miler in the wind yesterday... That's what I find fascinating (in a masochistic kind of way) about cycling, sometimes you are flying along feeling great and the next time out you feel like a wet dishcloth! However, I've been waiting for a good day for a while now
Oi, no cycling on my pavements! northwind Idle Banter 21 23-04-09 03:24 PM
Cycling to work MCN_LiamM Idle Banter 19 01-11-08 08:48 AM
The cycling thread! rob13 Idle Banter 11 27-08-08 02:00 PM
So what did I do to deserve this ( warning cycling based thread ) fizzwheel Idle Banter 45 16-07-08 11:05 AM
Cycling to France pencil shavings Idle Banter 2 18-03-08 12:28 AM
