Old 08-05-21, 08:50 PM   #2241
Adam Ef
Adam Ef's Avatar
Default Re: What have you tinkered with today?
Back on the VFR valve clearances. It's been a couple of weeks waiting for VTEC buckets /shims and took a while to remember what I was doing and what my notes meant. Started at 9am this morning and finished this evening (with covers and everything still off as I'm waiting for gaskets). All valves are now within spec. Pleased I got my calculations right first time as this is an expensive one on parts.
Past:
Old 08-05-21, 08:58 PM   #2242
admin
John T
admin's Avatar
You're a brave man.
Old 08-05-21, 09:27 PM   #2243
svenrico
svenrico's Avatar
wouldn't know where to start !
svenrico is offline   Reply With Quote
Old 08-05-21, 10:23 PM   #2244
Adam Ef
Adam Ef's Avatar
I can see why it costs so much to get it done now. I'm £150 down on shims and buckets and then there's the replacement gaskets and washers etc at about £260. That and the 3 days I've worked on it. I imagine it would take someone experienced in doing it at least a day.
Past:
Old 09-05-21, 12:06 PM   #2245
SV650rules
Originally Posted by DJ123 View Post
New front pads on the bike yesterday. Oddly one of the inner pads on 1 side was half the thickness of the other (hence the need for a change). The calliper & pistons are ok, no obvious signs of any underlying issue. I cleaned them up and re-torqued the disc bolts (floating set up) to make sure everything is aligned. Will see how this set go!
Thankfully pads are cheap at only £25 for the set (EBC).
In my experience uneven pad wear, with the pads on piston side wearing the most are down to sticking slide pins. I have used TRW PGF110 grease on slide pins on cars and bikes for many, many years without seeing a problem. What I did find is that if you use too much lube on slide pins it can cause 'hydraulic lock' in the blind hole where pins live, although the pins should have a flat machined onto them to allow air and lube to escape.
https://www.ebay.co.uk/p/23017012011
2016 SV650 AL7
Old 09-05-21, 12:09 PM   #2246
SV650rules
Originally Posted by admin View Post
You're a brave man.
I agree, but how did they manage to squeeze all that engine in there ?
My Brother has both a VFR750 and 800 and I don't think he has ever seen inside the cam covers.....
2016 SV650 AL7
Old 09-05-21, 05:08 PM   #2247
DJ123
DJ123's Avatar
My Callipers are 4 piston (2 pairs opposing each other - BMW F800ST). I've already ordered some retaining pins as they're not in the best of nick, no marks which would inhibit the return of the piston. But at 11 years old they probably need replacing!
BMW F800ST
Old 09-05-21, 09:02 PM   #2248
svenrico
svenrico's Avatar
I think motorcycles can become too complicated. There should be more consideration given in the design to ease of maintenance.
Old 09-05-21, 09:31 PM   #2249
Adam Ef
Adam Ef's Avatar
But then we'd all be riding single cyclinder bikes with drum brakes and elastomer suspension.
Past:
Old 09-05-21, 09:35 PM   #2250
admin
John T
admin's Avatar
You think that's bad, I've just read about changing the coolant in the MV 1000f4 in the latest copy of bikes magazine.
https://i.postimg.cc/rwK8gZdj/20210509-224002-01.jpg
Been got already today.. 454697819 Idle Banter 16 01-04-10 02:08 PM
Today DaveP The Border Patrol 4 02-03-10 10:52 AM
Going out today? tj2 The Border Patrol 1 01-06-09 09:22 PM
Today Tara Guildford Massive 14 02-06-08 11:56 AM
Today...... Caddy2000 Idle Banter 15 19-04-06 05:39 PM
