24-05-21, 09:54 PM | #2331 |
Re: What have you tinkered with today?
Tinkered thread became a discussion about pesticides for some reason.
+ Today I have been mostly trying to remove the Nitron shock from the VFR for a clean up. It would be easy if it wasn't the fancy version with remote compression and preload adjusters threaded through the subframe and ABS pump in the middle of the bike. Got there in the end. All while feeling like utter crap still. Trying to keep busy to not concentrate on how rubbish I feel.
>>> ? <<< Past: Street Triple 765rs, DRZ400s,GSXR1000 K9, VFR800 A8, ZX6R 636 2006, CRF250L, GSXR750 K7, VFR800 A7, GSXR750 L3, Street Triple 675R, MT09 Tracer, SV650s K8, CB250rsd, YBR125... Last edited by Adam Ef; 24-05-21 at 09:56 PM. |
24-05-21, 10:13 PM | #2332 |
29-05-21, 06:05 PM | #2333 |
bike being washed for the first time in about 4 years..... old faithful comes up pretty well.
29-05-21, 07:02 PM | #2334 |
Get yer polaroid out!
30-05-21, 12:04 PM | #2335 |
New rear wheel bearings for the bike. There's a bit of play in them, and being a single side swingarm with an eccentric adjuster for the belt - it's easier to change the whole assembly. Which is not cheap, by a means but is relatively easy to remove/replace.
01-06-21, 10:56 AM | #2336 |
This is from Sunday, but a few weeks back as I was getting ready for a track day, I removed the signal lights, in order to have one less thing to replace if I happened to come off. Of course the bolts on the rears were badly corroded and the whole fixing ripped itself out of the rubber stalks, on both sides
I wasn't particularly interested in LED replacements, especially paying for reasonable quality ones, so I used a bit of 2-part epoxy (Gorilla stuff in the syringe) to glue in some stainless bolts. So far holding up well:
- K9 SV650S: Hel brake lines, carbon end can - SZR660: The project... - K5 SV650S: K7 GSXR750 front end, ZX6RR shock, GB Moto rearsets, Hel brake lines, Renthal risers, Tuono bars, V-Rod headlamp, "JMV" belly pan ~SOLD~ (wonder where it is now) |
03-06-21, 07:46 PM | #2337 |
No tinkering but having recently sold my curvy svs, I have now bought another curvy svs, which should have been a naked! But it turned out to be a bit of a lemon. Not all bad news though the new svs curvy is an absolute peach so more than happy with my new purchase tbh. Handlebar conversion is first on the list plus god knows how many mods are in the pipeline!
05-06-21, 01:31 PM | #2338 |
Insulated the garage roof above the bikes' winter home. I'd noticed that the frost thawed off this area before the rest of the garage because of the dehumidifier. I also changed the plastic sheeting's attachment that isolates the bikes from the rest of the garage - it was held by large plastic clips but is now secured by a couple of battens.
2016 SV650AL7 2023 GSX-8S |
06-06-21, 04:43 PM | #2339 |
Fixed a small coolant leak on the bike. A seal i replaced a couple of years ago was starting to weep - relatively easy to replace, but it's location means its a coolant drain/refill & bleed.
06-06-21, 04:58 PM | #2340 | |
In these times a seal that starts to weep for no reason is gonna need counseling from a member of the victim alliance industry... who will tell you that weeping for no reason makes the seal a victim....
