#2411 |
Last chance for others to add input......
I think this will be the final tank position. I need to skirt around the bottom to increase the tank height approx. 2" down to the tank parameter hoop and shape to tank around the seat as a nice custom detail. I spit the rear to make it a bit wider and the expected skirt height measurements (mm) are written on the take at a few points. Next is make the base of the tank. |
#2412 |
Transferred my new number plate onto the tracer. It's now known as T90 FKU
#2413 |
Just making a trolley for my new welder today still needs wheels, handle, and toolbox.
#2414 |
Very tidy!
https://teulu.bandcamp.com/releases Blue Curvy S with over 110,000 miles and still going strong. ![]() |
#2415 | |
Where did you get the reg from ? Online?
>>> ? <<< Past: Street Triple 765rs, DRZ400s,GSXR1000 K9, VFR800 A8, ZX6R 636 2006, CRF250L, GSXR750 K7, VFR800 A7, GSXR750 L3, Street Triple 675R, MT09 Tracer, SV650s K8, CB250rsd, YBR125... |
#2416 |
#2417 |
Perfect reg for the T90 Trummy 62-68
#2418 |
Today I removed the clutch cover on my curvy, cleaned and thoroughly degreased everything, used a thin bead of black Granville rubberised gasket silicone in the O ring groove, placed the O ring back in the groove and sparingly smeared the O ring with same gasket goo. Refitted the cover and tightened down the bolts in a star pattern followed by torquing down. It has to be left for 24 hours to fully cure before riding so hopefully I've done a decent job and can say goodbye to any further leaks.
#2419 |
A step closer, only thing stopping me from using my tig is the missing hose to run between the regulator and the welder.
Should some rubber fuel line do the trick? I am thinking of mounting my little plasma cuter on the lower arm. |
#2420 | |
