28-08-21, 12:47 PM | #2431 | |
Re: What have you tinkered with today?
https://www.screwfix.com/p/no-nonsen...ser-5ltr/88668 Tip: Save any Surface cleaner spray bottles and mix up a strong degreaser solution in one. Makes it really easy to apply to things Screwfix Penetrating oil is a bargain as well for a really big 750ml can, https://www.screwfix.com/p/no-nonsen...il-750ml/19320
"Stultus est sicut stultus facit" Last edited by R1ffR4ff; 28-08-21 at 12:59 PM. |
28-08-21, 12:54 PM | #2432 |
John T
I've heard good things about that product. I'm going to try it once my current stuff is used.
28-08-21, 01:04 PM | #2433 | |
" I had to clean a motorbike engine that had a high up oil leak so was covered in thick greasy dirt. I tried muck off but the brushes were clogging up till they were unusable. I Put some of this neat in a container with soft long detail brushes and sprayed the bike as well. working between the header pipes with soft long brushes the grease came off easy without scrubbing. I swapped between brushes now and then but none of them clogged up even when i did the sump which was thick with dirt. I was very impressed with what this stuff can do it is cheap and smells fine i highly recommend it "
28-08-21, 01:58 PM | #2434 | |
John T
28-08-21, 02:55 PM | #2435 |
Funny you mention that. I had a few oil spots on my back concrete path and it worked great. Worked it in with an old Nylon toilet brush( Great for bike engines as well) and then just flushed it off after about 10 mins with a bucket of water
28-08-21, 06:38 PM | #2436 |
29-08-21, 10:35 AM | #2437 |
Bibio Rules!
big thumbs up for Screwfix no nonsense degreaser. its best stuff i have used by far and that includes paraffin. i'm very impressed. unlike paraffin you can wash this stuff off with just water and the grime just disappears. i used it neat then tried 50/50 mix with water and the 50/50 was just as good. i used a pup spray bottle to mist in on then a paint brush and hosed it off, grime gone ok so i would not go using it every wash but to get rid of the build up of crud once in a while would be perfect.
Was: K2 naked in rapid yellow - gone to a better? place Now: Street Triple R |
29-08-21, 10:41 PM | #2438 |
been using the degreaser for years.. its superb but its pretty crap on paintwork for which i still think Fenwicks Motorhome Cleaner is better, then a mist with Fenwicks Bobby Dazzler then a rinse with water.
01-09-21, 09:20 AM | #2439 |
re 27/08 Took rear brake all apart and checked ABS ring - just fine. No sign of damage on the ABS sensor cable. Put back, worked three days then light back on. Gave up, took it to the garage, just rang its diagnosed as a front brake issue!
01-09-21, 08:33 PM | #2440 |
Got the Street Triple just about back together and running again at last. I won't go into the details as I've had enough of it but it was a tricky one to say the least. And not a cheap service either even though I did it myself. Need to book it's MOT now.
>>> ? <<< Past: Street Triple 765rs, DRZ400s,GSXR1000 K9, VFR800 A8, ZX6R 636 2006, CRF250L, GSXR750 K7, VFR800 A7, GSXR750 L3, Street Triple 675R, MT09 Tracer, SV650s K8, CB250rsd, YBR125... |
