Old 28-08-12, 05:58 PM   #2471
fizzwheel
fizzwheel's Avatar
Default Re: The Cycling Thread
As said one of them undoes anti clockwise but I always get muddled up which one it is.
Whenever I try to get my pedals off they are always b*stard tight and I inevitably end up skinning my knuckles on the chainring. They can take a bit of force, but you want a smooth strong push to crack them undo rather than jabbing at it.
Stewie - if you are struggling dont force it. Is there a bike shop near you. Pop it in there and they'll pop them off for you.
Old 28-08-12, 06:10 PM   #2472
Left crank undoes clockwise, right one anticlockwise
Old 28-08-12, 06:10 PM   #2473
stewie
Cheers guys, I think I will pop it down to my lbs tbh, the bikes due a checkover anyway.
Old 28-08-12, 06:11 PM   #2474
Originally Posted by Jackie_Black View Post
they are both tightened the same way from the same side of the bike (if that makes sense) The left pedal has a reverse thread otherwise it would loosen as you pedalled.
Precisely
Old 29-08-12, 10:19 AM   #2475
krhall
The LBS used a step as a holder whilst using the spanner to loosen off, when I did it I spent ages, lost skin and got extreme tourettes and still couldn't do it.
LBS didn't even charge me.
Old 29-08-12, 10:24 AM   #2476
krhall
Ribble summer special on 0% looks tasty!
Old 29-08-12, 12:01 PM   #2477
Scoobs
Vipers Pillion Bitch
Scoobs's Avatar
I'm not sure I want to go down the custom frame build it up myself route. I know I could do it, but I just dont know if I would be able to put the time into getting the build done. I'd rather just buy from the LBS TBH.
What a tired git. I've just built up a new mountain bike and it took me less than 2 hours including cutting the steerer tube to length and cutting and bleeding hydraulic hoses for the disc brakes....but then i am pretty awesome.
I look good, I mean really good! Hey everyone come and see how good I look!
Scoobs is offline   Reply With Quote
Old 29-08-12, 12:03 PM   #2478
Scoobs
Scoobs's Avatar
PS. I'm just an interloper here. Won't be here long. Just came to berate my mate Fizz
Old 29-08-12, 12:18 PM   #2479
fizzwheel
fizzwheel's Avatar
Indeed, that is what my problem is I am not as awesome as Scoobs is...
Old 29-08-12, 12:22 PM   #2480
Scoobs
Scoobs's Avatar
It's in black and white so it must be true.
Get on and build a ped mate. Really satisfying to know that everything is as you want it and built with care and passion.
All the bolts on my bike are either copper greased or loc-tited as appropriate. Spindles greased where required. First ride after completing it is amazing. I thoroughly recommend a bike build to anyone.
Oi, no cycling on my pavements! northwind Idle Banter 21 23-04-09 03:24 PM
Cycling to work MCN_LiamM Idle Banter 19 01-11-08 08:48 AM
The cycling thread! rob13 Idle Banter 11 27-08-08 02:00 PM
So what did I do to deserve this ( warning cycling based thread ) fizzwheel Idle Banter 45 16-07-08 11:05 AM
Cycling to France pencil shavings Idle Banter 2 18-03-08 12:28 AM
